Tailgate load capacity
Old 11-07-2003, 06:16 AM
oric's Avatar
oric
oric is offline
does anyone know how much weight the tailgate can hold on it when open? Thats on a 2004 f350 psd..
thank you,Ray
Old 11-07-2003, 07:00 PM
BDU33's Avatar
BDU33
BDU33 is offline
Wink
Yeah...when it sounds expensive..its too much. No, really, I would think that the tech guys at Ford will know what the rating on the cables are. I'm guessing 4-5 hundred pounds? Maybe more, I dunno. I, and Im sure many others would like to know, what you're planning on doing with the tailgate to add enough weight to it that might make it crumple. Just curious. If you get any tech info please pass it along. Thanks.
Old 11-07-2003, 07:58 PM
BobJonesSpecial's Avatar
BobJonesSpecial
BobJonesSpecial is offline
How the load is distributed over the tailgate area would make a big difference. (All at one small point at the rear edge vs. evenly distributed over the entire area.)
I've seen three prety good sized guys all sitting on a tailgate at the same time. (700 lbs. maybe?) I think that would be about max, allowing a little bit for saftey.
BobJonesSpecial
Old 11-07-2003, 09:04 PM
Outpost22's Avatar
Outpost22
Outpost22 is offline
Believe it or not Ford rates them for either 100-200 lbs (I can't remember which). Their lawyers definitely got in on the ratings on this one
WE all know that they WILL hold a lot more than that
Old 11-08-2003, 10:04 PM
Like M. Fords's Avatar
Like M. Fords
Like M. Fords is offline
Had a logger come into the shop the other day with a new 2003 F350. I noticed that the tailgate was bent about an inch down in the middle. I asked him how it happened and he said just from stepping on it while carrying a 80# roller from one truck to another, and heard/felt a pop at the same time. He said he weighs about 250#.
So I would say 300# toward the end in the middle might be max. The 200# figure from Ford is probably correct for traveling down the road with that amount of weight on it.
These newer tailgates feel fairly light when you close them compared to the older trucks. Are there any built-in helper springs inside that take some of the weight off?
Old 11-09-2003, 10:52 AM
zedosix's Avatar
zedosix
zedosix is offline
I have often loaded 7 or 8 hundred pounds on my tailgate.Think about it for a minute, if you and 2 of your buddies sat on the tailgate thats probably in the 5 - 6 hundred pound load right there. If they can't hold that then there is a real problem. I found that my tailgate is actually heavier on my 03 than the 01 that I traded.
zed
coastaldc
1999 to 2016 Super Duty
01-18-2017 10:39 PM
stvneil
2015 - 2020 F150
10-23-2016 09:17 PM
Azuretruck
2017+ Super Duty
09-05-2016 09:16 PM
New To Ford
09-05-2016 01:33 PM
jowilker
10-27-1999 07:06 AM
Quick Reply: Tailgate load capacity
