Tailgate load capacity - Ford Truck Enthusiasts Forums
Old 11-07-2003, 06:16 AM
oric oric is offline
oric is starting off with a positive reputation.
does anyone know how much weight the tailgate can hold on it when open? Thats on a 2004 f350 psd..
thank you,Ray
Old 11-07-2003, 07:00 PM
BDU33 BDU33 is offline
BDU33 is starting off with a positive reputation.
Wink
Yeah...when it sounds expensive..its too much. No, really, I would think that the tech guys at Ford will know what the rating on the cables are. I'm guessing 4-5 hundred pounds? Maybe more, I dunno. I, and Im sure many others would like to know, what you're planning on doing with the tailgate to add enough weight to it that might make it crumple. Just curious. If you get any tech info please pass it along. Thanks.
Old 11-07-2003, 07:58 PM
BobJonesSpecial BobJonesSpecial is offline
BobJonesSpecial is starting off with a positive reputation.
How the load is distributed over the tailgate area would make a big difference. (All at one small point at the rear edge vs. evenly distributed over the entire area.)
I've seen three prety good sized guys all sitting on a tailgate at the same time. (700 lbs. maybe?) I think that would be about max, allowing a little bit for saftey.
BobJonesSpecial
Old 11-07-2003, 09:04 PM
Outpost22 Outpost22 is offline
Outpost22 is starting off with a positive reputation.
Believe it or not Ford rates them for either 100-200 lbs (I can't remember which). Their lawyers definitely got in on the ratings on this one
WE all know that they WILL hold a lot more than that
Old 11-08-2003, 10:04 PM
Like M. Fords's Avatar
Like M. Fords Like M. Fords is offline
Like M. Fords is starting off with a positive reputation.
Had a logger come into the shop the other day with a new 2003 F350. I noticed that the tailgate was bent about an inch down in the middle. I asked him how it happened and he said just from stepping on it while carrying a 80# roller from one truck to another, and heard/felt a pop at the same time. He said he weighs about 250#.
So I would say 300# toward the end in the middle might be max. The 200# figure from Ford is probably correct for traveling down the road with that amount of weight on it.
These newer tailgates feel fairly light when you close them compared to the older trucks. Are there any built-in helper springs inside that take some of the weight off?
Old 11-09-2003, 10:52 AM
zedosix's Avatar
zedosix zedosix is offline
zedosix is starting off with a positive reputation.
I have often loaded 7 or 8 hundred pounds on my tailgate.Think about it for a minute, if you and 2 of your buddies sat on the tailgate thats probably in the 5 - 6 hundred pound load right there. If they can't hold that then there is a real problem. I found that my tailgate is actually heavier on my 03 than the 01 that I traded.
zed
Tailgate stvneil 2015+ F150 1 10-23-2016 09:17 PM
Tailgate Latch New To Ford 1957 - 1960 F100 & Larger F-Series Trucks 2 09-05-2016 01:33 PM
Tailgate latch conchstew Explorer, Sport Trac, Mountaineer & Aviator 2 08-21-2012 01:25 PM
Tailgate Interchange Canus 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-29-2012 10:49 AM
Tailgate question Hausladen Paint & Bodywork 1 10-23-2001 07:34 AM
Tags
2003, capacity, copacity, f150, ford, gate, hold, line, load, loadbearing, sierra, tail, tailgate, weight, wieght
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
