F150 Load Capacity
F150 Load Capacity
I'm a little confused about what the actual load capacity of my truck is(ie: weight in the bed). My rear axle code is 19, so according to my owner's manual, the truck has a GAWR of 3800lbs. There is no way that the truck on it's own(unladen) is taking up 2800lbs of rear axle capacity, even with 2 full fuel tanks. Something isn't adding up here.
The reason I ask is that I have a load to haul 400 miles that weighs somewhere between 1200 and 1400 lbs, and I want to make sure that the truck can handle it safely.
Phobia16v ... check out this thread
https://www.ford-trucks.com/forums/s...%25252Bpayload
I and others had replied to this common question. You can also try a search on this forum on "f150 payload" (go one year back) for similar discussions.
Hope that helps -rlp
on
1 Post
FYI - yes, the 8.8 can take a 3800 lb load before things start falling off it. outside of the USA, with the contact overload option, there is an 'ambulance package' for the F150
not all f150s are 6250 GVWR tho....you need to peek at your little sticker. the 2wd models start around 5250 for a light duty shortbed stepside. I have the chart in my manual (which I still have!) but its snowing and 2* outside so tough.
keyul
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
19
03-28-2017 03:22 PM
95e150CW
06-24-2012 09:56 AM
Jrhere2003
06-10-2010 02:54 PM
