Bank 2, Sensor 1, 96 ford Explorer 4.0 - Ford Truck Enthusiasts Forums
Old 11-06-2003, 07:31 PM
Mikethomsen Mikethomsen is offline
Mikethomsen is starting off with a positive reputation.
Hello, I have a 1996 Ford Explorer 4.0 Liter. I have a check engine light on and I took it to Autozone to see why it was on. They scanned my computer and said that it was a O2 Sensor. They said it was bank 2 sensor 1. I bought a new sensor for it and put it in on the drivers side, close to the Transmition. And the check Engine light still come on. Took it back to autozone and they rescaned it and said it was still Bank 2, Sensor 1. We reset the computer and I have drove about 500 miles and it still stays lit up. What am I doing wrong? Do I have it in the right place? Please help
Old 11-09-2003, 06:48 AM
r3830 r3830 is offline
r3830 is starting off with a positive reputation.
Mike,
From what you have written.....YES, it is in the right place. The fault codes make mention of both upstream and downstream sensors. My '97 has 2 on each pipe - yours may well have the same. If you can get the fault codes they are specific to top and bottom sensors. (there are 3 different fault codes for each upstream sensor!)
Keep at it!
Paul.
Old 11-09-2003, 01:38 PM
franklin411 franklin411 is offline
franklin411 is starting off with a positive reputation.
This is a good example of how computer code outputs aren't exactly perfect. I recall having the same code you have, on the same exact vehicle (1996 Ford Explorer 4.0). I also replaced the O2 sensor, but the code didn't go away. It would come and go, seemingly randomly. In passing, I read up on O2 sensors, and one book I read said that an O2 code can come up as a result of things like bad gas or engine mechanical problems. Got my fingers crossed, b/c the code's been gone for about 6 months now, and in the meantime, I replaced a leaky head gasket. So I'd say, check all your sensors and do a tune-up if you haven't already done so. That could be the problem!
4.2 V6 Engine light after pulling spark plugs, got the codes from autozone jbourne84 3.8 & 4.2L V6 1 02-16-2016 11:10 AM
1997 ford f150 o2 sensors richyd 1997 - 2003 F150 26 10-30-2012 07:11 AM
03 Explorer 4.0 V6 Flex Engine Code Please Help ShouldaBoughtAToyota Explorer, Sport Trac, Mountaineer & Aviator 1 07-31-2008 10:04 AM
Explorer O2 Sensor Codes 97ExplorerEB Explorer, Sport Trac, Mountaineer & Aviator 14 07-26-2007 09:50 PM
bank 1 oxygen sensor 96 explorer djn24 Explorer, Sport Trac, Mountaineer & Aviator 5 07-20-2004 07:41 PM
Tags
1996, 1997, 2002, 2003, 40, 96, bank, bank2, code, explorer, find, ford, problems, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
