"Good morning Vietnammmm!" I mean arizona! Its a beautiful day out side, going to be quite warm through monday but fall is on its way and it will be cooling down tuesday. Have a good weekend everyone!
Hey Crawler
Way to be on the spot September post.
Way down here in Texas we were suppost to have some good weather and low humidity. all of the weather men were posting that. Well its cooler but the humidity is still way up. I think those guys are just voices for the computer forcast.
If my right knee aches then 2 days later the temperature will drop 10 degrees. AMybe we should go around the FTE site and get weathermen from each chapter and then we could post the weather for the the US. I bet it would be better than the other teleprompter readers.
We have one weather woman down here, But for some reason I never hear a word she says, cant figure it out.
Good! i am working on making a bracket for the brake calipers today.
and i figured out why the rotor had 1/8th inch of runout, i did not have it mounted on the machined surface as it should be. a few washers fixed that.
Sounds good, so do you still have a long list of to dos?
Oh yea! after i get the calipers and brackets done i need to run the brake lines and then replace the brake master and some hard lines and run an inline porp valve for the back brakes and replace the tierod ends and mod the drag link and have it aligned.... all of which i would not have a klew how to do if not for this website. 3-4 weekends maybe.
if you run out of projects Bill come up here, I have a 49 f100, 49 f500, 28 model A, 58 chevy 2 door, 70 cj5, john Deere B, G and M and an 80 chevy step side 4X4 that need restored.
