CR - Octane - Timing
I'm just about finished rebuilding my 360 into a 390. Depending the accuracy of my measurements I put my CR at somewhere in the range of 9.5:1 to 9.75:1. I used 390 crank and rods, with 360 pistons (flat top with 4 valve reliefs), a felpro head gasket, and stock heads (no decking). I want to get started on the right foot and figure that I may need to replace the 87 octane that is sitting in the gas tank. I assume the timing will be somewhere between 12 and 15 advanced. Any suggestions on which gas and timing should work out well? By the way, I live in the flatlands of NC, so no major altitude, and the pumps here offer 87, 89 and 93.
Thanks,
Mark
Thanks,
Mark
I wouldn't go to the trouble of replacing the gas. Consider that tank your break-in tank and take it easy. If it pings, back-off the timing until it stops. Do all the tuning adjustments when that tank is empty, the engine is a little more broken-in, and you have the gas in the tank that you intend to burn in the future.
66_in_ky
08-22-2007 10:16 PM
moonley
03-19-2007 09:07 AM
