cruise control not working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-05-2003, 10:50 AM
Orlie Orlie is offline
Orlie is starting off with a positive reputation.
2000 F-250 4X4 V-10 The cruise control is not working at all. Is there any thing I can check to repair this myself.
later
Orlie
Old 11-05-2003, 10:52 AM
dinebito dinebito is offline
dinebito is starting off with a positive reputation.
is your abs light on?
Old 11-05-2003, 11:16 AM
Foneguy Foneguy is offline
Foneguy is starting off with a positive reputation.
I have the same problem and have yet to have the time to figure it out... I first thaught it was because of all the wiring I had to do with the WD Turbo Brake. but I've checked in with WD and they said I don't mess with any of the wiring pertaining to the Cruise Controll. I have no other light's on the dash that may show that there is anything else affected. And I have yet to take it to FOMOCO. because I am not sure if it has something to do with what I have installed on the beast. Any info or expierences with this would be greatly appreciated.
YMMV
Your Resident Foneguy
Old 11-05-2003, 11:43 AM
I have no abs light on or any lights on. This might sound kind of dumb, but what about a fuse. I haven't had time to look at the problem so I need some ideas.
later
Orlie
Old 11-05-2003, 05:06 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
Don't know your model, but I have a 94 F250 460. Almost everytime I work on the passenger side of the engine, usually the plugs, I lose cruise control.
The cause in my case is that my arm bumps the vacuum lines that go to the AC box near the firewall. The vacuum lines are plastic looking things that go into black rubber connectors. The lines are either 2 or 3 per connector. The connector can be unseated enough to kill cruise but not be visibly obvious.
Sooo, go check each vacuum line by hand. It costs nothing to check, takes maybe 1 minute and at least in my case it is usually the cause of non working cruise.
Note that I also occasionally get an engine code set when the connector is off. I do not think the vacuum actually controls the cruise, but it sends a signal to the computer that I think the cruise uses.
Either way it works for me and best of all it is free.
Also check you fuses in the cab and under the hood. Trace all the wires or connections from the cruise controller to make sure they are clean and tight.
Good Luck,
Jim Henderson
Old 11-05-2003, 05:21 PM
dayseizer dayseizer is offline
dayseizer is starting off with a positive reputation.
You ABS Tease!
Hey DineBito, my ABS light IS on, and my cruise control does nothing. I was going to start looking at fuses, etc for the cruise when I saw your post. Does the cruise get disabled if the ABS is reporting problems?
Old 11-05-2003, 10:13 PM
nafzimo's Avatar
nafzimo nafzimo is offline
nafzimo is starting off with a positive reputation.
Re: You ABS Tease!
Quote:
With these symptoms, you may consider replacing the speed sensor in the rear axle housing. It is about a $20 part and easy to change. Oh, and don't be alarmed when your OD light starts to flash.
Old 11-05-2003, 10:31 PM
DS02F250 DS02F250 is offline
DS02F250 is starting off with a positive reputation.
Orlie,
I seem to remember having a cruise control problem on a car I had before. It was an easy and relatively inexpensive fix, even at the dealership, so don't let them talk you into a new cruise control unit right off the bat.
I agree with the earlier posts: check the fuse and vacuum connections (cc does use some vacuum), then try the speed sensor, THEN consider full replacement if the cc unit truly is SHOT.
Daryl
Old 11-06-2003, 01:18 AM
Shepard Shepard is offline
Shepard is starting off with a positive reputation.
Does your horn work when pushed? If not, it may be your clock spring.
Old 11-06-2003, 07:08 AM
for orlie; SURELY check fuses first. also, could it be switches in steering wheel? try pressing EXTRA hard on them and see if it kicks in. (i went thru 2-sets on my last vehicle).
for dayseizer; SURELY try replace rear diff sensor. $24 at dealer and very easy R&R. DS is right, and its pretty likely your problem. to my knowledge, ABS provides square wave signals over vehicle BUS from the wheel speed sensor inputs, so... no ABS, perhaps no CC...
Old 11-06-2003, 05:23 PM
bigdawg460 bigdawg460 is offline
bigdawg460 is starting off with a positive reputation.
Re: cruise control not working
Quote:
later
Orlie
Ok,first there is nothing vacuum operated on your cruise.i would check the fuse ,but you will be lucky if thats all it is.A few things it could be,your servo,brake light switch,brake pressure switch, speed sensor ,or the buttons.There is a way to get a code out of your cruise servo.I believe you have the key off,then while holding the on button on the steering wheel turn the key on,the cruise light blinks once if the servo is ok,then within 3 seconds of the light blinking once you press off, resume ,coast, set.the cruise light should blink once for every button you press,and if it does then your buttons all work.,and after you hit the last button it will blink a code 1 through 5.Im trying to remember this all from memory so i hope its right.i think 1 blink at the end means pass,i really dont remember the rest of the codes.one is brake light switch one is the deactivator switch(brake pressure switch),and i think another is the servo.The cruise didnt work on my excursion when i got it,and it was the brake pressure switch.its the little switch on the end of your master cylinder,mine was actually leaking brake fluid out.if you jump the connector on the pressure switch and it will bypass it.thats how i made sure that was the problem after i got my code.and it worked.25 dollars for the part easy as pie.hope this helps,and i hope i am remembering right.
Old 11-07-2003, 09:39 AM
jaxf250's Avatar
jaxf250 jaxf250 is offline
jaxf250 is starting off with a positive reputation.
Simple fix - my bet is the brake pressure switch like bigdawg says. See my gallery here on FTE for a link to some pix at how to replace it. 3 minute fix.
Old 11-07-2003, 04:18 PM
To expand on my earlier post. I have seen two newer trucks where the cruise just stopped working. On one, (mine) the airbag light came on also. On the other no other lights came on. In both cases, the horn would not work when pushed. (It did work with the remote lock, however). In both trucks the clock spring was bad. We were both told (by different dealers) that this is not an uncommon problem.
So push your horn. If it works, it is probably something other than the clock spring. If your horn won't blow, I think you have found your problem.
Old 11-21-2003, 07:22 PM
kmans777 kmans777 is offline
kmans777 is starting off with a positive reputation.
Hi guys, Just started having the no cruise control and ABS light illuminated. Dealer said they could be related as supported by what I'm reading here. Tried the check bigdawg suggested and got no cruise light during any of the checks. Tried the horn check as suggested by shepard, horn works. So I've seen 3 suggestions here, brake pressure switch, speed sensor, or brake pedal position switch(bpps on another post). Question- if bigdawg's check is valid, would any of these switches/sensors make his test fail?
Also could any of these have an effect on the SRS(seat and safety restraint system). I'm getting the chimes indicating a fault of some sort.
Daysiezer- Have you corrected the problem?
And to jax- thanks for the link,
Old 11-21-2003, 07:31 PM
Waxy's Avatar
Waxy Waxy is offline
Waxy is starting off with a positive reputation.
Dimes to donuts it's the rear diff speed sensor.
Like nafzimo said, $20 and ten minutes in your driveway should fix it.
Waxy
Cruise Control Jterr 1999 to 2016 Super Duty 5 10-20-2015 08:42 PM
2005 5.4 cruise control Dgmisho12 New Member Introductions 4 06-07-2015 09:29 AM
cruise control ramhunter5877 2004 - 2008 F150 4 10-12-2014 10:10 PM
2002 Ford Expedition Cruise Control Not Working hawesra Expedition & Navigator 2 07-21-2014 09:01 PM
Cruise Control njstevens Excursion - King of SUVs 11 02-09-2012 10:38 AM
Tags
1988, 2004, control, cruise, duty, f250, faulty, ford, fx4, quit, relay, super, superduty, troubleshoot, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
