cruise control not working - Page 4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #46
Old 09-18-2011, 09:49 AM
smithrngr smithrngr is offline
smithrngr is starting off with a positive reputation.
, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
what switch is it?
mine just quite last week,no abs light or anyother light.the cruise light comes on when i hit the set button and goes out when the brake or off switch is hit but no cruise.changed the switch on the end of the master,and nothing.run the test all the buttons work and i can hear the motor kick on.
  #47
Old 10-19-2011, 01:47 PM
FX4 Fighter Pilot FX4 Fighter Pilot is offline
FX4 Fighter Pilot is starting off with a positive reputation.
Quote:
Originally Posted by burtr@netsmithinc.co View Post
I have a similar problem to the ones described here. It started with my airbag trouble light on the dashboard. It comes on all the time and occassionally flashes 3 times then 2 times. My buddy at the Ford dealer says it is a clockspring error code. Over a couple of weeks I lost my horn, CC, and now my ABS light comes on. Sometimes the ABS light doesn't come on and when I pull to a stop the ABS system activates and the pedal gets really sketchy. I recently started getting a noise like a starter solenoid clicking when I start the engine. I had that once before and it turned out to be a bad battery. Last time I couldn't start the truck when that sound occurred. This time it starts OK. THe way this stuff happened made me suspect a wiring harness in the steering column going slowly bad but it seems like most of the solutions here are related to the clock spring. Where is this darn clock spring and how do I replace it? Any other suggestions?
I have the same issue with my '07 F-250. Mine started with the CC not working - light not illuminating at all 4 weeks ago, and the airbag light started flashing 3 times and then 2 times then will remain on. I just replaced my MC Brake switch thinking that would be the quick fix for the CC, but still no workie. Were you able to get your Airbag light to go out and CC to work again??
  #48
Old 10-19-2011, 04:58 PM
smokemangrp smokemangrp is offline
smokemangrp is starting off with a positive reputation.
Quote:
Originally Posted by doo71dene View Post
i used the self diagnostic test and it passed, still have to check the speed sensor, what mine is doing is i push the cruise "set/accel" button and it flashes momentarily but that's it, every time i push it the same thing happens i have a 2000 f-250, v-10, super-crew, 196000 miles, has anybody else had the same problem? CORRECTION!!!! today i went out and checked it again and it shows three flashes (deactivator open or not functioning) can anybody tell me where the deactivator switch is? is it the brake pedal switch?
this is a fusible link they installed due to a recall, something about brake fluid leaking onto the wires and shorting out, had a buddy whose truck burnt up because of it! i think my cc problem might have something to do with this because my cc light on the instrument cluster would flash momentarily when i pushed the set button and after i moved these wires around now it don't do anything
Mine also gets the 3 flashes, (deactivator open or not functioning). Where would I find this fusable link that doo71dene mentions?
Also, for those who don't get any flashes after pressing ON, be sure to press the resume IMMEDIATELY, as the instructions state. At first I wasn't fast enough and assumed the righthand switch was bad.
  #49
Old 10-23-2011, 07:57 PM
cnvF250 cnvF250 is offline
cnvF250 is starting off with a positive reputation.
Question
I have a 2002 f250 with a V10 cruise doen't work
A lamp flash with the last button (SET/ACCEL) indicates that the static test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
OK, I have the following after doing the mentioned test. Pretty easy to do, Thanks.
Where is the BPP switch? It is an automatica transmission so I wouldn't think it is a CPP switch.
Picture would be greatly appreciated. I can fix anything if I can see it first.
  #50
Old 10-24-2011, 08:49 AM
Drivingmad44's Avatar
Drivingmad44 Drivingmad44 is offline
Drivingmad44 is starting off with a positive reputation.
question about brake switch
I have a '97 E150 (5.4L w/E4OD). My cruise control hasn't worked since I got it, I've replaced the switches on steering wheel and the release switch on the master cylinder and still nothing.
I just bought an Equus Innova 3150 scanner that does OBDII, CANII, ABS, and Trans codes. It can up with a code for the brake switch, would this affect the Cruise Control? Just thinking maybe because it does disengage the cruise when you depress the pedal.
Any ideas?
I've tried the test mentioned here (pressing the switches in sequence) and get nothing.
  #51
Old 10-27-2011, 07:57 PM
Well That didn't work. I replaced the BPP switch (Easy job 10 minutes max). I still have the same 2 flashes at the end of the test sequence.
I guess I will try the cruise control deactivator switch on the Master Cylinder. Do you guys know if I will have to bleed the brakes when I am finished with the replacement?
  #52
Old 10-27-2011, 08:14 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
No, you won't have to if you're fast! I had my new one ready to go in right as I was taking the old one out. I only lost a few drops of brake fluid doing the swap.
The bad new is, that didn't fix mine.
Based on the troubleshooting section of the shop manual, my problem is the cruise control servo
  #53
Old 10-29-2011, 09:58 PM
pYr8's Avatar
pYr8 pYr8 is offline
pYr8 is starting off with a positive reputation.
Hi All-
I had started another thread before I found this one.
Having intermittent CC problems here on my '01 F250 7.3 turbo. My cruise will work when it wants to, engaging most the time but will quit on bumps or even sometimes with no apparent jarring. It occasionally seems to be temperature sensitive but it's hard to say as I've only had it since last December.
Today is the first time I dedicated any time to troubleshooting it. From what I'm gathering, the CC cuts out at the same time as the brake lights firing. My brake lights come on with as little as 1/8" pedal movement, VERY sensitive! Could it just be the "mercury switch" type of switch under the dash at the pedal or would the pressure switch at the end of the master cylinder also cause this? I've tried the CC self-test, never got the CC lamp to light, and I KNOW that bulb works.
It would be handy for it to work properly, sometimes long trips trailering the bass boat can leave my legs numb, LOL...
Thanks
Karl
  #54
Old 03-16-2014, 05:29 PM
SoYouCanSuperDuty's Avatar
SoYouCanSuperDuty SoYouCanSuperDuty is offline
SoYouCanSuperDuty is starting off with a positive reputation.
Ok I got 2 flashes I tried replacing BPP still doesn't work. Still get two flashes. It's automatic so that eliminates CPP. Where do I start for circuit is defective?
  #55
Old 11-01-2014, 02:00 PM
Gideuup Gideuup is offline
Gideuup is starting off with a positive reputation.
2005 Ford F150 Brake lights, rear running lights not working
My problem: No brakes lights, no rear running lights, no directional's in the rear and cruise control effected by this as well.
I have headlights and everything wks up front and dome lights. If I use a directional it blinks quickly but not in the rear of the truck. Cargo brake light works, tail lights are very dim. Cruise control wks sometimes but noticed if it is working and I put the directional on, the cruise control will shut off and not wk again for a while.
I've changed bulbs, fuses, and the flasher switch under the drivers side dash near the brake pedal and the other flasher on drivers side all the way to the left connected to the dash board which Napa Auto parts has all. Nothing worked. Took it to a Mechanic and he said he thought it was from a trailer brake I had installed about 5 mths ago and the problem was in the steering wheel because of the directional's and cruise control are there.This was not it.
Turns out I took it to the place that installed the brake for my horse trailer. And the problem was a short in the ground wire people.
Yes, this pain in the you know what for a whole wk trying to figure this out is due to the ground wire being shorted out. He just disconnected the old ground and ran a new ground wire and all it working GREAT!!!! He charged me only for the labor $85.00
I read about this on Google and it says Ford is known for grounds shorting out and suggests to check one that supposedly is behind a kick panel on the drivers side. I didn't get to check this but its worth checking if your having issues but if you can fix this your self. Your way ahead of the game Good luck and I hope this works for you.
  #56
Old 03-16-2015, 08:01 AM
BillC1009 BillC1009 is offline
BillC1009 is starting off with a positive reputation.
2005 cruise
Just now jumping in on this thread after replacing the sensor on the master cylinder. Cruise is still out - no codes, no lights. I tried the test, holding the buttons down and turning the key, but I don't get anything - no lights at all. I do not have an ABS light on, horn works, brake lights work, everything is good to go, except for the cruise. I also bought a rear diff speed sensor but the connector is wrong. Not sure what the deal is there, but the connector I bought is a Motorcraft, so it should be plug and play but it's not. Anyone else have that issue? Is there a different speed sensor for early and late model 05s?
  #57
Old 03-16-2015, 08:29 PM
tsummar tsummar is offline
tsummar is starting off with a positive reputation.
Quote:
Hey Bill I am having the exact same issue on my 2002 f250 v10. I have replaced the speed control valve on the master cylinder and do not get any codes when I do the test.
  #58
Old 03-17-2015, 11:45 AM
Quote:
Gremlins....
TSummar - did you have your truck repaired with the recall? Supposedly they didn't replace the switch with that recall, but they did put a fuse in the line, which would short if the sensor had brake fluid leak into it. I'm thinking that the recall covered up to 2003/04 trucks, so yours might have that fuse issue. Mine doesn't have a fuse at all, either in the line or in the fuse box, so I'm not sure which direction to go now.
  #59
Old 03-17-2015, 10:34 PM
pYr8's Avatar
From what I gather, the test doesn't work on diesel trucks. My code reader doesn't do much of anything either. I'm gonna just start replacing things...
  #60
Old 11-10-2015, 08:55 AM
thegrizzly1 thegrizzly1 is offline
thegrizzly1 is starting off with a positive reputation.
Hi all, working on in-laws truck, and found this wonderful site with a little searching. Thanks to the info in this thread, I was able to run the self diagnostic. Came up with trouble code 3. I pulled the electrical connector off of the BPP switch (Cruise Disconnect Switch) on the end of the master cylinder and sure enough it was full of brake fluid and the wires were saturated. My understanding is this is a normally closed circuit and opens when it sees brake pressure. I jumpered the two wires at the connector to the BPP switch (disconnected from the switch of course) and still no CC. I believe there should be voltage at one of the two wires at the BPP switch connector. What is that voltage, is there only power when the cruise "on" button is pushed, or do I have to be above the 35 or so MPH and hit the set button to see voltage at the BPP switch? I have a sneaking suspicion, the wires have finally shorted out somewhere and I am not getting any voltage to this point. The CC did work a few months ago. There is no pigtail with a fusible link near the BPP switch, however there was a blue tag saying something to the effect of a non serviceable fusible link somewhere in the harness. I am assuming this had the recall update due to the blue tag. My next questions would be where is the fusible link physically located?
Thanks in advance for the help.
Cruise Control Jterr 1999 to 2016 Super Duty 5 10-20-2015 08:42 PM
2005 5.4 cruise control Dgmisho12 New Member Introductions 4 06-07-2015 09:29 AM
cruise control ramhunter5877 2004 - 2008 F150 4 10-12-2014 10:10 PM
2002 Ford Expedition Cruise Control Not Working hawesra Expedition & Navigator 2 07-21-2014 09:01 PM
Cruise Control njstevens Excursion - King of SUVs 11 02-09-2012 10:38 AM
Tags
1988, 2004, control, cruise, duty, f250, faulty, ford, fx4, quit, relay, super, superduty, troubleshoot, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
