cruise control not working - Page 3 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #31
Old 01-09-2004, 03:12 AM
kmans777 kmans777 is offline
kmans777 is starting off with a positive reputation.
Krometoez- I am starting to see a pattern with my gremlins. When we have a couple of days of steady rain, that is when my problems begin. I have discovered a water leak running down the l/h windshield post. When the carpet mat gets wet, then things start going wrong. Don't know yet if it's the windshield(which was replaced just prior to my purchase) or the door seals. Will keep you posted.
  #32
Old 02-14-2010, 10:39 AM
Drivingmad44's Avatar
Drivingmad44 Drivingmad44 is offline
Drivingmad44 is starting off with a positive reputation.
I realize these are all OLD postings but, let's give it a shot anyway.
I have a '97 Econoline 150 and my cruise doesn't work at all, I've checked the fuses (speed control and horn, everything ok). Now, it had an alarm and remote start in it and I had it swapped out with a new unit, could the wiring to the brake light switch have anything to do with this?
  #33
Old 06-17-2010, 11:26 AM
bigobob bigobob is offline
bigobob is starting off with a positive reputation.
check to see if the GEM is getting wet
  #34
Old 06-17-2010, 09:03 PM
nothing is wet, could it possibly be the switch on steering wheel?
  #35
Old 09-06-2010, 06:58 PM
9402fordguy's Avatar
9402fordguy 9402fordguy is offline
9402fordguy is starting off with a positive reputation.
Question Also having cruise problems
So I noticed today I lost the use of my cruise control.
After reading bigdawg's test procedure, it gave me a code 3... whatever that means....
I opened the hood and thought I would check the pressure sensor that was mentioned and found this.....
What the heck is it?
I should mention, I just had the truck into the dealer for a complete front brake job, exhaust manifold studs, and axle seals....
It seems that they plugged a new harness in, but it isnt hooked to anything, the old plug is just laying there.... should they be plugged together and do you think that might solve my no-cruise issue?
Thanks
  #36
Old 09-06-2010, 08:06 PM
After doing another search on google for codes, I came up with this from another ford forum.
Quote:
*cruise control self test*
Enter self-test diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel
will flash once to indicate that speed control module entered the diagnostic mode. Five additional flashes at this point indicate a defective speed control servo. Release the OFF switch.
Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
If the ON switch is not depressed within five seconds after entering the diagnostics mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
NOTE: There will be a slight delay when the last button is pressed and the lamp flashes.
A lamp flash with the last button (SET/ACCEL) indicates that the static test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
3 flashes - deactivator switch is open or circuit defective.
4 flashes - vehicle speed signal is out of range or circuit is defective
Immediately (.25 second delay) after the static test, the speed control servo does a dynamic test by automatically actuating the throttle lever from 8 mm (0.315 in) to 12 mm (0.472 in) of travel from the idle position. During the dynamic throttle pull, observe throttle movement to witness any binding or sticking of the speed control cable and correct connection of speed control cable to throttle lever. Make sure the throttle returns to the idle position.
I should note that after a little reckless bravery, I decided to hook the 2 plugs I showed together and perform the test, which gave a 'pass'. Then took it for a drive and the cruise works again. Just thought I would post my findings for anyone's future reference.
  #37
Old 09-06-2010, 09:07 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
Quote:
Originally Posted by 9402fordguy View Post
reckless bravery
Heh heh... good one, I like that term.
Congrats on getting yours working again. Mine has been a real PITA. I've used the test procedure and replaced the switch in your pics and then the brake pedal switch (per the test results) still with no luck. I went through the test procedure in the manual and it says I need to replace the servo. I forget what the dealer wants but its in the $300 range. If I ever get time I'm going to buy one from a truck recycler or something and try it.
  #38
Old 11-05-2010, 07:16 AM
doo71dene doo71dene is offline
doo71dene is starting off with a positive reputation.
passed self diagnostic
i used the self diagnostic test and it passed, still have to check the speed sensor, what mine is doing is i push the cruise "set/accel" button and it flashes momentarily but that's it, every time i push it the same thing happens i have a 2000 f-250, v-10, super-crew, 196000 miles, has anybody else had the same problem? CORRECTION!!!! today i went out and checked it again and it shows three flashes (deactivator open or not functioning) can anybody tell me where the deactivator switch is? is it the brake pedal switch?
  #39
Old 11-05-2010, 05:36 PM
this is a fusible link they installed due to a recall, something about brake fluid leaking onto the wires and shorting out, had a buddy whose truck burnt up because of it! i think my cc problem might have something to do with this because my cc light on the instrument cluster would flash momentarily when i pushed the set button and after i moved these wires around now it don't do anything
  #40
Old 11-22-2010, 12:33 AM
Kountryguy Kountryguy is offline
Kountryguy is starting off with a positive reputation.
Can anyone tell me how to get to the cruise on-off switch on my 2000 F-350? It works sometimes and not others.
  #41
Old 02-05-2011, 08:44 PM
sodsaver sodsaver is offline
sodsaver is starting off with a positive reputation.
Ran the test. The Off and On buttons worked but the others did not. I'm assuming those buttons/switches (coast, resume and set/decel) are bad???
Before it went totally out, the cruise light would come on and then intermitent, then totally out.
Is it an easy replacement? Will it interfere with my air bag if I start replacing the switches? Do I need a whole new sterring wheel/air bag,etc...? Any help appreciated.
__________________________________________________ ________________________
2002 XLT 4X4 Super Duty 5.4L
  #42
Old 02-06-2011, 10:24 PM
mine ended up being my speed control disconnect switch, (on the end of the master cylinder), $24.00
  #43
Old 05-12-2011, 03:57 PM
Mine is givin' me FITS! Changed the sensor on the rear diff, changed the "release switch" on the master, today I changed the switches on the steering wheel -- still nothing. I tried the "hold off button, turn key on" test and I get NOTHING! My horn works all the time, my brake lights work all the time, my ABS light comes on periodically. Should I just jack up the radiator cap and slide a new van under it?
  #44
Old 08-02-2011, 07:16 PM
Kennicol Kennicol is offline
Kennicol is starting off with a positive reputation.
My cruise control stoped working today. I tried the press off button turn key on but the cruise light didn't come on. its a 2001 f250 v10. the fuse under dash is ok.ownners mannual didnt show a fuse under the hood. any other suggestion thanwhat alreay been posted
  #45
Old 09-02-2011, 03:00 PM
Mike E. Mike E. is offline
Mike E. is starting off with a positive reputation.
Love this place!!
Cruise stopped working on Wednesday.
Spent Thursday 'readin' up' and pulled the connector off the disconnect switch on the master cylinder, jumpered out the connector, and voila, cruise works.
This morning headed over to Ford, got the new switch (which also comes with another pigtail to plug into the recall pigtail) and after 20 minutes had it changed out. Tested: all good.
Thanks everyone!!
Mike
Cruise control not holding speed mksnipe 1999 to 2016 Super Duty 11 12-15-2015 08:22 AM
Cruise Control Jterr 1999 to 2016 Super Duty 5 10-20-2015 07:42 PM
2000 Ford Excursion Cruise Control Problems? Mitchell_Texas Excursion - King of SUVs 36 08-22-2015 07:14 AM
2005 5.4 cruise control Dgmisho12 New Member Introductions 4 06-07-2015 08:29 AM
Cruise Control njstevens Excursion - King of SUVs 11 02-09-2012 09:38 AM
Tags
1988, 2004, control, cruise, duty, f250, faulty, ford, fx4, quit, relay, super, superduty, troubleshoot, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
