distributor spout connector? 1995 f-150 5.0 4x4 manual tranny
does anyone have an idea where the spout connector for the distributor is on my truck? i found and coninuiteed the conductor that goes from the distributor connector to a connector that goes to a condensor, it looks like a condensor. does anone know if i check my timing without disconnecting what i should get? and if you can tell me what iam supposed to get with the spout connector disconnected? my label on the hood says disconnect the spout connector and i should get 10degrees btc. who knows i have run into a wall right now. oh well thanks for any and all help for i need it.
thanks again
thanks again
On my 90 F150 w/5.0L, the spout connector is near the distributor, in the bundle of wires that goes to it. It's basically a pair of wires with a receptacle (sp?) that looks like it just has a spacer filling the end. That spacer is actually a small jumper that breaks the circuit that abvances the timing. The 5.8 also has 10 deg. btdc with the connector undone. Connected, it jumped to about 16-18 deg. btdc, advancing more with engine speed, of course, to about 30 deg. btdc.
Hope this helps!
Chuck
Hope this helps!
Chuck
Gino ,
There is no need to cut into the wires ...the Spout connector is 2 single wires about 6in long , next to the distributor with a Grey Cap ...this cap is the part you remove to check the timing . Spout stands for Spark Out , all this little grey connector does is stop the computer from adjusting the timing so you can check that the base timing is correct . Once it is unplugged , check and adjust the timing if needed . Be certain you reinstall the cap after you are done otherwise the timing will not advance when needed .
Paul
Paul
Thats where it is on my 1993 F-150 with the 302 aswell.
***********PASTMASTER***************
1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
rusty70f100
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
08-11-2006 10:44 AM
mpmccarthy
07-08-2004 12:08 AM
