Man, this new bed lines up pretty good on this '59...
Straight from the builders mouth!!!!!!!!!
Here is what the owner said.
"FIRST OFF, THE FRAME HAD TO BE EXTENDED 8" TO PICK UP THE REAR FLOOR X MEMBER OF THE BED. THE EXTENSION ANGLES WERE TURNED TO EXTEND OUTWARD BECAUSE THE BED MOUNTS ON THE NEW BED ARE WIDER APART. THE BED HAD TO BE SHIMMED UP APPROX 1 " TO BRING THE LOWER BED BODY LINE TO MATCH UP WITH THE BODY LINE ON THE CAB. THE WHEEL OPENING ALIGNED PERFECT WITH THE REAR WHEELS. THE UPPER FRONT BODY LINE ON THE BED WAS FILLED TO ALOW THE BED TO LOOK LIKE IT WAS MADE FOR THE TRUCK. THE REAR OUTSIDE EDGES OF THE CAB WERE ALSO FILLED IN SMOOTH.
PS. THE TRUCK IS FOR SALE ! ASKING $20,000.00"
Doesn't sound too bad. One of y'all jump on it and then tell us if it is as easy as it sounds.
