Oil pressure???
Old 11-04-2003, 10:18 AM
E350turbo's Avatar
E350turbo
E350turbo is offline
Oil pressure???
I just bought my first Diesel, it's a 1989 E350 ambulance with a 7.3, and 104,000 miles. I had the engine cover off this weekend, and was surprised to find a "remanufactured dealer engine" sticker on the valve cover, and the engine looks new, not any dirt or dust anywhere.
I took it for a cruise, and it runs flawlessly. But, I noticed when idleing, the oil pressure drops to almost zero on the stock gauge! But the engine still sounds fine. If the oil pressure was dropping that low, wouldn't I hear a bunch of clatter(even worse than normal for a diesel) like a gasser does? The engine idles great, but the oil pressure worries me.
Old 11-04-2003, 11:30 AM
Jens's Avatar
Jens
Jens is offline
Hi,
it's the same with my engine. If you want to be sure you can install an aftermarket oil pressure gauge in conjunction with the stock one.
Jens
Old 11-04-2003, 12:00 PM
E350turbo's Avatar
E350turbo
I am going to order a after market gauge today. I am just worried to drive it till I get it installed.
Thanks.
Old 11-05-2003, 10:37 AM
Spectramac's Avatar
Spectramac
Spectramac is offline
Most engines I've run a manual gauge on only idle at 15-20 pounds when hot. They will go to about 45-50 wound up.
Never believe the factory gauge (unless it goes to zero), get a second opinion.
Poorboy04
09-11-2020 08:22 PM
DennisA (IL)
1999 to 2016 Super Duty
01-02-2018 11:02 PM
Tom Callan
04-19-2016 08:30 AM
antiqbob
07-30-2015 11:32 AM
asemastermech
175
12-11-2013 12:08 PM
Quick Reply: Oil pressure???
