Removal of Plastic Bed Rails
well there are some pretty tough plastic clips that go through the top bed .if you take a look from under the truck looking up towards the rail you'll see them.
A trick we used to use in the bodyshops was to take a heat gun on low heat soften the tabs if there warm they'll pop out easier.
The one in the tail gate ,you have to remove the access panel ,then there are special scrivets used to hold this in place. Make sure you have new
scrivets before removing .
Rich
Rich
Well, my tailgate cover came off quite easily. While loading my quad, the ramps slipped backwards a bit (resting only on the plastic cap), and WHOMP! Down went the ramps holding the quad with me on it. When I got up, I picked the plastic cap up, looked at the dent on top of the tailgate (almost cried) then put the plastic cap back on. Pretty easy, and it's in there pretty good. When I pulled it off when I got home, I kinda rolled in backwards (away from the bed) and it came right off.
Sounds like somebody is gonna be asking Sanny for a hydraulic hoist to put the buggies in the bed.
I think Hjudge49 is really Robbie Kneivel, although he didn't mention that the truck was moving when the quad jump was being performed (sweet!) Evel taught you well...
In Phoenix they all start out black plastic, by fall they are all gray and warped anyway. Some Einstein thought it was real cool to put a black plastic tailgate handle on there, probably disfigured my fingerprints enough to hide from El Federales now. Wish I had color schemed handles off an X, I'm starting to wander, need RF hub assy.... call dealer w/o anger ..... breathe.... breathe..... out
FordTruckfan89
07-25-2016 11:52 AM
tcrimsonk
17
01-08-2012 09:10 AM
