Crank & Rod bearing torque specs; '77F250, 351M
11-03-2003, 07:23 PM
on
I am R&R the crank and rod bearings on a new (to me ) 1977 F-250 w/ a 351M. I need to know the torque specs for each.
Please help!:
11-03-2003, 10:02 PM
on
rod bearing bolts 40-45 ft.lbs
main bearing bolts 35-45 ft.lbs
crankshaft balancer bolt 70-90 ft.lbs
flywheel to crankshaft bolts 75-85 ft.lbs
All info from chilton manual
11-04-2003, 09:24 AM
I think you need more than that for mains. I always go to the book for torque specs as memories can wander.
11-04-2003, 10:18 AM
Main bearing bolts on the 351M/400 should be torqued to 95-105 lbs/ft.
11-04-2003, 06:51 PM
Some aftermarket manuals (including Chiltons) incorrectly list the main bearing cap torque at 35-45 ft lbs. That is the torque spec for the smaller secondary cap bolts on a 4-bolt 351C engine.
The correct main bearing cap torque is 95-105 ft lbs.
11-05-2003, 05:52 PM
on
torque specs
Quote:
Thanks for the info guys! Do you know the specs for the rod bearing caps?
gatnos
11-05-2003, 05:56 PM
11-05-2003, 06:00 PM
on
torque specs
40-45 lbs/ft.
Thanks! So to refresh the crank is 95-105ft-lbs and the rods are 40-45ft-lbs.
I'll post a picture and tell everyone how the truck runs when I'm complete in about a month.
Thnaks again!
06-04-2020, 05:25 PM
on
help?
help me on the torque specifications for a 2000 f250 v8 Gas Triton
06-05-2020, 11:44 AM
Gess
Modular V8 (4.6L, 5.4L)
03-13-2017 02:47 PM
PapaBearYuma
16
11-12-2016 10:42 AM
C.W
Modular V10 (6.8l)
03-23-2013 01:49 PM
sum_weirdo
08-02-2011 08:14 PM
beaners1
06-10-2008 05:55 PM
2002 ,
30 ,
351 ,
351m400 ,
70 ,
bearing ,
bearings ,
crankshaft ,
escape ,
ford ,
main ,
ranger ,
rod ,
spec ,
specs ,
torque
