239 fan spindle bearing and impeller shaft - Ford Truck Enthusiasts Forums
Old 11-03-2003, 03:43 PM
jeffh's Avatar
jeffh jeffh is offline
jeffh is starting off with a positive reputation.
Question 239 fan spindle bearing and impeller shaft
OK, the garage working on my Tank is trying to locate a fan spindle bearing and impeller shaft , and they think that the (1950) F3 would have a different size than the F1. I've found these parts in eight or nine different catalogs and they just say they're for the 239 V8, no mention of body style. Does anyone here know for sure if I need different sizes or not? Thanks...
Old 11-03-2003, 06:00 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Buy him the parts for the F1 and tell him they're for an F3. They use the same engine, radiator, mounts, etc,etc.....
I have a 51 merc V8 in my 48 F1 that has a 49 F3 front sheet metal and I had to install my backup radiator for awhile - it's out of a 46 1 1/2T grain truck. All this stuff swaps identically.
F1 to F6 used the same engine and cooling system. You should be good to go with F1 parts.
Old 11-05-2003, 04:23 PM
jeffh's Avatar
I thought that was the case, Tim. I stopped by the shop yesterday and hopefully talked him into ordering the parts anyway (heck, found them in 9 different catalogs...) Thanks for confirming my suspicions...
Old 11-11-2015, 12:58 PM
medctr1's Avatar
medctr1 medctr1 is offline
medctr1 is starting off with a positive reputation.
Fan spindle bearing now available
Call Van Pelt sales...they are having 100 of these Fan Spindle Bearing made and will be in stock soon.......Finally!!!~!
292 Water pump and pulley BelgianF100 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 02-02-2016 10:21 PM
Need a Fan Hub for '51 F3 239 Flathead V8 randycarmichael 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 11-11-2015 01:01 PM
Turbo went boom - replace or repair? jinxie 6.0L Power Stroke Diesel 2 05-24-2014 09:31 AM
1949 F-1 Flat Head V-8 Fan Spindle Bearing Charlie & Old Red 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 06-18-2012 08:26 PM
impeller shaft play howmuch herrfixit 1999 - 2003 7.3L Power Stroke Diesel 7 05-10-2006 09:04 PM
Tags
1948, fan, ford, impellor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
