loose steering on my 89 f-350
first you have to find out what is causing the steering slop. it could be any of the 4 tierods connecting the 2 wheels to the steering box, then the steering box could be worn out.
first check the tierods and the balljoints on the end of the axle,the steering box can be adjusted if needed
Careful with the adjustment, too tight will blow up the box quick. Haynes manual has a procedure that has you pull the pittman arm and check torque to turn the column, but I just tightened mine down a little bit at a time and made sure that the wheels turned nice and free (jacked up the front and turned tires side-to-side by hand). I'm not expecting more than a few thousand miles out of the steering box anyway though but it seems to be working nicely after adjusting.
Just make sure it's not tie rod ends/ball joints before you touch the adjustment.
portsample
04-09-2020 09:32 AM
fordmarshall111
02-08-2011 11:13 AM
