1999 Ford Ranger Overdrive Transmission problem
Yesterday my 1999 Ranger 2.5L Automatic got really wierd! The check engine light came on, the overdrive light started flashing, the ABS light came on, and the transmission can't shift out of low, except manually...and to top it off the speedometer quit working! What the heck is going on???? This has got to be all connected somehow. Do any of you experts have an idea so as to advise me before I get hosed at the dealership??
Up until now, I have had no problems. The truck has about 45K miles. I change the oil at 3-4,000 miles and try to take care of this as my teenage daughter drives this truck to school.
Any help would be appreciated. Thanks.
does any body know what the speed sensor looks like? what is on the auto parts pages doesnt look like any thing on my transmission. i cleaned a switich looking thing on drivers side of tranny with wd40 and speedo came back but was very itermitent. and shifting very weird. any info greatly appreciated. thanks
The rear ABS speed sensor isn't on the tranny, its atop the front center of the rear differential housing/pumpkin, held in by one 10mm fastner & an "O" ring on the sensor.
Clean dirt off around the old sensor before removing it, so you don't have any fall in & contiminate the differential oil. Lube the new sensors "O" ring before installing, torque the fastner to 25-29 ft/lbs, clean & lube the speed sensor electrical connector seal with silicone grease before reinstalling it, make sure it snaps closed & your good to go. Maybe a 15-30 minute install, most of the time spent getting jack, stands & raising & lowering the vehicle.
Do a parts search for the rear ABS speed sensor, to see what it looks like, or refer to your repair manual for its looks & location on the rear differential.
Already done what????
The rear differential mounted speed sensors PID output is used by the ABS,
Tranny, Cruise Control & Speed-o, so if those other things are acting out, that speed sensor, its electrical connector & wiring belong on your suspect list.
Do you have a CEL lit???? If so, most autoparts stores will scan the computer for trouble codes, then post All code Numbers, as they can offer up good trouble shooting clues.
ok went on to other sites have determined that there is only one vss on this 1999 ranger.... even though auto parts stores carry a part there is no place for it on the 98 99 00....... the one on the rear end is the only one, so something between it and the cab must be wrong i guess, real hair puller, codes dont show nothing,,, really though i feel sorry for some of the ladies on other sites that used a book to determine what was wrong and parts store sold them the part that has no place to go and the stores would not refund money. had a south of the border mechanic try to tell me shifter is out of adjustment i havent even started on that.....
Well a Ford Dealer can reprogram the computer for the tire size you have on there now & I've read they may charge from nothing up to $45, or .7 hours time, so that the speed-o is calibrated & the tranny shift points are right. A good tire shop may be able to do it too, or someone with a re-programmer. I've read it can be done going through the ABS module, which will then correct the GEM module to make everything right.
Yah I too used to think all the electronic gizmos on the newer vehicles were overly complicated & not necessary, but since being on this forum for a while & learning some about how most of the systems work, it really isn't that bad & the computer can make the engine perform a lot better quickly, so it gets better mpg & runs cleaner & when something goes wrong, the computer can tell us where it hurts, so it can make trouble shooting easier.
Think of the computer as a brain, the sensors as its nerves, providing feedback on what they're monitoring & actuators as fingers, to do the computers bidding which is based on the feedback its getting from its sensors & its programming which is a set of instructions that tells the computer how to process/evaluate its sensors info, all a neat circle when everything is working as designed!!!! lol
More thoughts for consideration, let us know how it goes
