Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 11-12-2003, 11:26 PM
Cm snipe is starting off with a positive reputation.
well if you look at the plugs you see both of them have the fat end right after the threads both of equal length.so they are both gonna stop at the same point.i just replaced mine at 76,000(now i have 84 something on the odometer) there autolite triple platinums from discount autoparts.autolite is the same as ford plugs so yeah.... its best to replace them cause your firing system will be a lot smoother instead of the oil coated plug.just be glad none of them are green for which youll know you have a bad head gasket. but just put the thing in.
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 11-13-2003, 05:50 AM
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
Quote:
The plug has 2 electrodes, how do you get triple platinum?
Double platinum is what Autolite and Motorcraft makes (each
electrode has platinum).
  #18 (permalink)
Old 11-13-2003, 08:15 AM
well the autoway ford dealership sell triple platinum plugs along with the other plugs.cause i used to have a 89gt an i got the new plugs put it in what i bought it an the plugs ran around 7 bucks each and if you dont believe that there is triple platinum heres an example at summitracing......Triple platinum plugs
  #19 (permalink)
Old 11-13-2003, 08:21 AM
I'm sorry, but I wouldn't even put a Splitfire plug in my lawn mower!!! These are a SCAM!!!!
Show me a Motorcraft, or Autolite "triple platinum" ......
  #20 (permalink)
Old 11-13-2003, 08:31 AM
well heres what i found at motorcraft website.they dont call it the triple platinum plug they call it the finewire platinum.third one down on list finewire platinum (fords triple)
  #21 (permalink)
Old 11-13-2003, 08:36 AM
No, the finewire platinum is also a double platinum......
  #22 (permalink)
Old 11-13-2003, 09:41 PM
rudiger66ca is starting off with a positive reputation.
Quote:
Originally posted by aerocolorado
The additional threads on the new plug make no difference because the plug does not thread all the way down. Look at the picture again closely. They both have the same shoulder height. Each plug is turned down until the shoulder contacts the head and seats. On the new plug, those additional threads will never be used. Probably less expensive to just machine them all the way up once the mill lathe is running.
  #23 (permalink)
Old 11-14-2003, 01:13 AM
ckrichard's Avatar
ckrichard is starting off with a positive reputation.
Do they mill the threads or do they roll them. I always thought they were rolled. But you may be right since the threds on the plugs are so sharp.
Chris
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
