1996 F150 XL not firing - Ford Truck Enthusiasts Forums
Old 07-15-2000, 11:46 PM
gator gator is offline
gator is starting off with a positive reputation.
I have a 1996 F150 XL 300 6cyl. It's not firing consistantly. It took about thirty minutes to crank it. It turns over but it only fires about one out of thirty times.I am getting fire to the coil but it's not getting past the coil. I would appreciate any advice you can give me.
Thanks
Gator
Old 07-16-2000, 12:33 AM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
Gator ,
The only thing that I can think of looking thru my diagnostic routines is that the TFI / Pickup coil in the dist is the problem . The TFI instructs the coil to saturate and fire and since yours is firing spordically I would suspect thats the problem . Since the coil fires sometimes it makes me want to lean toward the TFI as the cause . Usually coils either work or they dont . Replacing the pickup coil in the dist along with the TFI seems to be the best practice when the TFI fails . How many miles on your truck ? Any other problems before this current one , any related problems ?
Paul
Old 07-16-2000, 06:57 AM
joewrenchhead joewrenchhead is offline
joewrenchhead is starting off with a positive reputation.
GATOR,
WHAT KIND OF FIRE TO THE COIL?12 volts BATTERY
POWER AND SWITCHING SIGNAL?OR ONLY THE 12 volts?
IF YOU'RE ONLY GETTING BATTERY POWER CHECK ALL
YOUR IGNITION ELECTRICAL CONNECTIONS AND GROUNDS.
USE CAUTION WITH TEST LIGHTS AND MULTIMETERS,THEY
NEED TO BE HIGH IMPEADANCE TYPES TO PREVENT DAMAGE
TO THE ELECTRONICS.
GOOD LUCK
JOE
Old 07-16-2000, 06:37 PM
Ron Ron is offline
Ron is starting off with a positive reputation.
Along the lines of region-specific trim packages ctubutis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 10-19-2014 01:42 AM
Duraspark II/HEI conversion failed sixofspades Ford Inline Six, 200, 250, 4.9L / 300 1 02-14-2014 09:23 PM
1972 ford f250 with a 390 will not go over 30 mph chunk101 1967 - 1972 F-100 & Larger F-Series Trucks 39 02-14-2014 09:20 PM
04 navigator codes billymac1961 1997-2006 Expedition & Navigator 7 12-08-2013 02:31 PM
Front end conversion. Expy to 'gator. nismoz21 1997-2006 Expedition & Navigator 2 03-19-2005 07:49 AM
Tags
1996, 96, coil, f150, fire, firing, ford, intermittent, makes, power, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
