Drain Plug for A4Ld Transmission - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 11-01-2003, 08:22 PM
SmittyD SmittyD is offline
SmittyD is starting off with a positive reputation.
I would like an easier way to change the transmission fluid in our Bronco II. Has anyone installed a drain plug kit in an A4LD or should I buy a pan with a plug in it?
Thanks,
Smittyd
Old 11-03-2003, 08:02 PM
MJB MJB is offline
MJB is starting off with a positive reputation.
Buy a drain plug pan.
Old 11-05-2003, 07:25 PM
Thanks -- I was leaning toward the pan with the plug.
Thanks again for the reply,
SmittyD
Old 07-04-2013, 01:07 PM
RockEagle RockEagle is offline
RockEagle is starting off with a positive reputation.
Are you kidding me? I've got to buy one? They were that dumb back then Hugh?
Old 07-05-2013, 06:23 AM
Georgeandkira Georgeandkira is offline
Georgeandkira is starting off with a positive reputation.
Hello, Yes, they were. Kira
Old 07-05-2013, 09:24 PM
mdr617's Avatar
mdr617 mdr617 is offline
mdr617 is starting off with a positive reputation.
does sound like an odd thing, but I have found that many transmissions lack this, including some C-6's.
Old 07-07-2013, 11:42 PM
belchfire belchfire is offline
belchfire is starting off with a positive reputation.
This is an unfortunate thing on some fords. I've popped-drilled a hole and let it drain then brazed a pipe fitting on for future times.
Old 07-17-2013, 12:45 PM
BII Plow Truck BII Plow Truck is online now
BII Plow Truck is starting off with a positive reputation.
I'd just buy a $3 plug kit from NAPA and install it in the pan. It comes with everything you need, incl instructions.....just use 1/2" drill bit and you're done!
Old 08-22-2013, 07:25 PM
crazy96863's Avatar
crazy96863 crazy96863 is offline
crazy96863 is gaining momentum as a positive member of FTE.
Since you have the pan already I would try the kit. If you jack up the install you are out nothing to very little since you are already willing to obtain a whole new pan.
If the kit appears to be really cheap or poor in quality, look for a better kit but NAPA usually has good stuff. Just do a little quality assurance on your work and if it doesn't seem up to par, replace it.
I just said the same thing two different ways. Wtfe.
Old 04-03-2014, 09:43 PM
Shanook9080 Shanook9080 is offline
Shanook9080 is starting off with a positive reputation.
Buy a pan with the drain plug on it.
A4LD Transmission survey dmix48 Aerostar 10 02-15-2016 10:36 PM
3.0-4.0 a4ld BigLoo Aerostar 2 08-26-2011 09:50 AM
A4LD Transmission puttypusher Ranger & B-Series 3 06-29-2005 05:19 PM
A4LD 3-4 shift solenoid Dave462 Clutch, Transmission, Differential, Axle & Transfer Case 2 06-17-2004 01:00 PM
Would a 94 A4LD work? wolffpax Bronco II 4 08-21-2003 10:33 PM
Tags
1996, 2008, a4ld, bronco, capacity, drain, edge, fluid, flush, ford, location, plug, tranny, transaxle, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
