Is Bank 1 on passenger or driver side? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 11-01-2003, 08:14 PM
kamsho kamsho is offline
kamsho is starting off with a positive reputation.
Can anybody tell me cylinder bank 1 is on driver or passenger side?
Also, O2 sensor #1 is before or after cat?
Thanks
Kam
Old 11-01-2003, 09:07 PM
turbo TED turbo TED is offline
turbo TED is starting off with a positive reputation.
Hey kamsho bank one is on passangers side & sensor 1 is the first one going from front to back on passangers side also.
good luck turbo ted
Old 11-01-2003, 09:28 PM
Oh my god.
How am I going to replace that one!
I can see the sensor and the connector from underneath the truck but I can't reach the connector.
Any body has changed the O2 sensor on the passenger side?
Old 11-02-2003, 01:56 AM
BigMattXXL's Avatar
BigMattXXL BigMattXXL is offline
BigMattXXL is starting off with a positive reputation.
Quote:
Yeah, it's a real PITA, but you can do it. The secret is this: you must remove the transmission dipstick tube. It's only one bolt, diretly threaded into the block. After that, the tube just pops out from where it's connected to the tranny.
Of course, before you do this, you must jack it up, put a jackstand under it, remove the front passenger wheel, undo a couple of bolts that hold the wheel-well plastic-thingy in, fold the plastic thingy back so you can see what you're working with, then remove the tube.
Honestly, I fumbled with it for about 2 hours before removing the tube. After that, I was done in 10 minutes.
I'm about 99.9% sure it's not possible without removing the tube.
XXL
Old 11-02-2003, 08:56 PM
XXL
XXL:
How did you finish in 10 minutes after the removal of trans dipstick?
I did the same but I could not even close to move the sensor.
I was using a O2 sensor socket with a flex head rachet. I could barely fit the rachet and socket in there.
Any tips as to make the sensor move or lose?
Thanks
Kam
Old 11-03-2003, 12:02 AM
BigMattXXL's Avatar
XXL:
Thanks
Kam
It's easy - I used a wrench. Can't remember the size; it was a pretty big, standard wrench just to break the connection, then removed the rest of the way by hand. I also cut the wires between the sensor and the electrical connector, so when I started loosening the O2 sensor, it wouldn't get all bunched up and fight me. After the sensor came out, I undid the clip that had the wires attached to it, and installed the new one.
XXL
Old 11-03-2003, 11:09 AM
XXL:
Are you using the wrench on the base of the O2 sensor?
Is there enough room for the wrench to move?
Thanks
Kam
EGT left bank and right bank Magnus E 6.0L Power Stroke Diesel 5 09-09-2016 11:05 AM
2006 ford f150 misfire/poor accelleration fixed hofec1 2004 - 2008 F150 30 09-01-2016 07:17 AM
Plug wire routing 92F150Flare 1987 - 1996 F150 & Larger F-Series Trucks 18 06-25-2015 06:25 AM
Question related to 02 sensor locations ???? jorge995 1997 - 2003 F150 3 07-21-2013 05:03 PM
SPARK PLUG WEAR (banks different) kev100 Explorer, Sport Trac, Mountaineer & Aviator 7 03-24-2003 01:54 PM
Tags
02, 1997, 1999, 2005, bank, driver, expedition, ford, located, oxygen, passager, passenger, sensor, side, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
