Gas pedal sloppyness
Okay, So the pivot point looks a lil worn where the pedal was rideing. so i used pliers to push it over on to the splines so its tight, cause i dont see a way to get this thing off.
Now, wheni reach up under to where the cable is, there is a lot of slack. And i notice it while driveing. when you let off the gas, it takes a second to rev down while the cable retracts itself.
I can adjust this cable tight to the pedal right?
And as for the tension on the cable, I would have to go to the trottle body and make sure that the spring for the cable is lubricated and working properly?
its got about 1 cm of slack. Which isn't to great.
So, it looks like just a pin comming through then a cap. Is there a second cap behind it for pushing the cable back through?
