EOD Transmission Problem - Ford Truck Enthusiasts Forums
Old 08-11-2000, 11:06 PM
boatdocks boatdocks is offline
boatdocks is starting off with a positive reputation.
I recently bought a 1992 F350 Crew Cab with a 351 V8, Electronic Overdrive Transmission, and 82,000 miles. It seems it's "geared low" since it changes gears at a much higher speed than the F250 I had before. There is also a slight kick between gears. I've been told that there is a speed sensor in the dash that sends the speed rate to the transmission computer and from there it tells the tranny when to shift. If the speed sensor isn't working, the tranny goes into "fail-safe" mode and changes gears based on engine speed, hence the late gear shifting. The tranny fluid level seems to slightly above the cross-hatched area when checked properly. All I'd like to know is if this speed sensor could be the culprit? Is there another easy fix? Any applicable info will help me with transmission repair guys who'll tell me I have to do major work to the tranny and not the speed sensor. Thanks.
Old 08-14-2000, 01:50 AM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
96 F250. Tranny problems. Speed Sensor? BuckHammer 1987 - 1996 F150 & Larger F-Series Trucks 15 03-26-2016 05:47 PM
not sure if i have tranny issue or not....info? gimptank 1999 to 2016 Super Duty 3 05-19-2013 10:20 AM
tranny problem corndogjim 1999 - 2003 7.3L Power Stroke Diesel 3 05-13-2011 01:45 AM
1991 E40D Transmission shifting problem dieselbogging Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-15-2006 06:32 PM
E4OD Transmission guitar_god2003 Clutch, Transmission, Differential, Axle & Transfer Case 4 02-22-2003 10:11 PM
Tags
1996, cluster, culprit, diesel, eod, f150, ford, instrument, overdrive, problems, reliability, repairing, transmission, transmissions, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
