Brake Upgrade for '95 F150?
Old 08-12-2000, 05:30 PM
ajstephan's Avatar
ajstephan
ajstephan is offline
My '95 F150 4x4 braking is a little scary. It has rear anti-locks that pump away at a "sudden" stop. I'd like to improve the braking. Is there a relatively simple brake upgrade I could do? Say, from a F250 or other Ford?
I was thinking I could either get bigger discs on the front (hopefully from another Ford rather than an expensive aftermarket conversion) , or put discs on the back, but I don't know enough about anti-lock brakes to know if I could retain them with rear discs.
Old 08-13-2000, 01:41 AM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
I think in 98 Ford first offered rear disc brakes on F150 's . The abs should still operate if you switch to discs in the rear since the system is activated from a trigger gear & sensor mounted in the rear diff . Four wheel discs offer more efficient braking which should reduce rear wheel abs operation . Plus discs are far easier to service than drum brakes .
Old 08-13-2000, 10:39 AM
ajstephan's Avatar
ajstephan
Good to hear that the ABS can be retained. I can't imagine that there are many '98s in the wrecking yard, but is this a "direct" swap or do you know if it will take some fabricating?
Any info would be appreciated. Thanks.
Old 08-13-2000, 11:40 AM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
There are aftermarket sources for rear disc brake conversions . I assume you have the 8.8 Inch rear diff ? http://www.stainlesssteelbrakes.com . Im sure there are other companies that deal in the same sort of thing for price comparisons .
Old 08-13-2000, 11:17 PM
ajstephan's Avatar
ajstephan
8.8" rear diff??? I guess I assumed that F150 came with 9" rears. If 8.8" are standard for F150s, then I have to assume that your correct.
The manuals I have don't tell me anything. (although I did learn that I have 3.55 gears - some news since I assumed 3.08s given its sluggishness.) That would also explain why my rear end grenaded at 60K miles. However, a 8.8 rear end should open up a lot of options for rear discs since the Mustang aftermarket is so good.
Is there an easy visual check?
Old 08-14-2000, 12:50 AM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
The 9 In rear diff was used up until 87 I think ? If Im wrong on the date someone will correct me . Im pretty sure your truck will have the 8.8 rear diff .
Old 08-14-2000, 12:04 PM
dan4x4's Avatar
dan4x4
dan4x4 is offline
purecty
42
07-05-2015 01:32 AM
jmmartin
03-23-2010 01:33 PM
Gorgoth
07-16-2009 02:59 PM
Shovelhead 93
01-28-2008 12:53 PM
Shopguy
1999 to 2016 Super Duty
05-26-2005 07:50 AM
Quick Reply: Brake Upgrade for '95 F150?
