Coil Spring Spacers - Ford Truck Enthusiasts Forums
Coil Spring Spacers
Old 10-31-2003, 08:36 AM
76Chateau 76Chateau is offline
76Chateau is starting off with a positive reputation.
Coil Spring Spacers
Does anyone now if the spacers for coil spring will fit a 76 E150 van with twin I-beam,Ian running 31 /10.5 /15 .Would like a lift of 1 to 2 "so it doesn`t bottem out .Or if their is a set of truck coil springs that would fit.The springs where replaced within the last month.
Old 10-31-2003, 08:41 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I use a set of the twist in spacers in my 77 F150. You have to use the thicker ones. 1 1/2" thick I believe.
Jimmy
Old 10-31-2003, 10:58 AM
beartracks's Avatar
beartracks beartracks is offline
beartracks is gaining momentum as a positive member of FTE.
I wouldn't recommend the twist in type. There are however aluminum molded one's that go on top of the spring. I don't know how thick you can get them.
Old 10-31-2003, 11:06 AM
grapegravy's Avatar
grapegravy grapegravy is offline
grapegravy is starting off with a positive reputation.
I think the preference between twist-in or non strictly depends on your driving style. If off-roading, driving over a lot of rough roads or potholes, then don't go with the twist-ins. If it's a daily driver around town, don't worry about, you won't have the side to side or compression/release movement of the spring to loosen them.
Old 10-31-2003, 02:04 PM
Ecuri Ecuri is offline
Ecuri is gaining momentum as a positive member of FTE.
You can pick up around an 1" or maybe a bit more by unbolting the bottom spring retainter (big nut in side spring on bottom) and shimming it up. I guess also you could replace the bolt (with a really good quality one) with a longer one and shim it as high as you wanted to. No offense but those twist in things are a crime against nature and not, IMHO, a substitute for the right spring. Your camber is going to go to heck after this adjustment. GL
Old 01-15-2012, 02:54 PM
FordIowan FordIowan is offline
FordIowan is starting off with a positive reputation.
Where to buy coil spring spacers
I was wondering where I could buy front coil spring spacers for my 78 F150 4 X 4. I couldn't find them on Bronco Graveyard. Any ideas?
Old 01-15-2012, 03:19 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
I have coil spacers on my Ranger. They mounted on the bottom spring on top of the I-beam. Worked like a charm, but compressing the springs to reinstall them was a pita.
Josh
Old 11-15-2013, 02:15 PM
bear_ bear_ is offline
bear_ is starting off with a positive reputation.
The twistin work just fine on the road.
On the sand dunes not so good
I have the inch and a half rubber booster. I lifted the front of my truck. I sprayed the spring with WD 40 and tapped it in with a rubber mallet.
Old 11-15-2013, 08:12 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
There is a company that makes a coil spring spacer/top block for 73-79. Its design is like for newer trucks, but will work, I am looking for it....
coil springs Vs. coil spacers? ravens fan 1987 - 1996 F150 & Larger F-Series Trucks 18 02-23-2011 05:46 AM
coil spring spacers or stiffer springs cowman435 1987 - 1996 F150 & Larger F-Series Trucks 16 02-20-2011 02:57 PM
Coil Spring Spacers bending coils??!! savageford 1999 to 2016 Super Duty 6 01-05-2010 08:19 PM
coil spacers bradplock 1978 - 1996 Big Bronco 5 01-20-2007 06:21 PM
coil spacers roguebronco36 1978 - 1996 Big Bronco 7 12-29-2001 01:56 AM
Tags
1977, 1979, 77, 84, bronco, coil, f100, f150, f250, ford, spacer, spacers, sping, spring, twist, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
