88 Ford F-150, 302 FI Swap to 351 Carb. Engine
Old 09-02-2000, 10:40 PM
fjones's Avatar
fjones
fjones is offline
I'm helping a friend rebuild a 351 engine removed from a 76 Ford van. The engine will be installed in an 88 Ford F-150, 4x4 that has a 302 fuel injected engine. We are going to remove the computer controlled sensors. The truck has TFI ignition and we want to go to the DuraSpark ignition the van has. Looking at the electrical circuit diagram the TFI ignition doesn't have a ballast resistor needed for the DuraSpark ignition. Could anyone that has done a swap like this give me some help on the easiest way to do this. Thanks.
Old 09-04-2000, 12:11 AM
roscoe's Avatar
roscoe
roscoe is offline
There are way many other more experienced people on this site other than me...but here goes anyway. I just did a EFI to carb swap. It was 1978ish 6 cyclinder motor into a 1986 EFI. The ballast resistor was mounted on the passenger side fender well instead of the coil next to the (and attached to) voltage regulator, as I recall. Hope this helps some...
Old 09-04-2000, 04:37 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
I don't have an answer to your question, but is your engine a Modified or a windsor? If it's a modified, do you intend to use the transmission from the van too?
FYI, the the Modified has a big-block bolt pattern and will not connect to the tranny in the F-150.
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
Old 09-04-2000, 07:26 PM
fjones's Avatar
fjones
fjones is offline
The engine is a windsor.
Old 09-04-2000, 10:35 PM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
fordboy300
05-12-2011 10:14 PM
LARIAT 85
06-01-2007 05:42 PM
LARIAT 85
08-29-2006 11:47 PM
CJ7
12-01-2003 05:46 PM
1988ford
12-26-2002 08:22 PM
Quick Reply: 88 Ford F-150, 302 FI Swap to 351 Carb. Engine
