IAC repair Help - Page 2 - Ford Truck Enthusiasts Forums
IAC repair Help
Old 12-22-2003, 09:01 PM
dubldare dubldare is offline
dubldare is starting off with a positive reputation.
I just paid $140 for an IAC for my '97 Crown Vic.
Hurts the pocketbook a bit, but I learned my lesson several times on various auto-electronics. Nothing surpasses the quality of OEM parts.
darren
'97 p71-199,930 miles
'98 EB V8 Exploder-62,000 miles
Old 01-04-2004, 02:46 PM
4.0 Beast's Avatar
4.0 Beast 4.0 Beast is offline
4.0 Beast is starting off with a positive reputation.
Ok, I also have a 4.0L sohc engine, but the picture looks totally different from mine. I have a 1992 and i used the picture but couldnt find my IAC valve. If anyone knows or has a 1992 and can tell me where the IAC is on my truck, it would be cool. A picture would be better than describing.... Thanks.
Old 01-16-2004, 08:29 AM
FireMarshal3311 FireMarshal3311 is offline
FireMarshal3311 is starting off with a positive reputation.
Dying when shifted into reverse?
My wife's 98 sohc 4.0 every onece in a great while will die when you back up and stop then put in drive. It runs really good most of the time and this has only happened about 5-6 times last year. At idle it sometimes seems as if it is going to die then goes back up to normal, a little shutter, or stutter than smoothes out. Could this be the same thing, just not totally bad yet?
Great post Wolfmiester
Old 01-16-2004, 09:39 AM
thelonerangerxlt's Avatar
thelonerangerxlt thelonerangerxlt is offline
thelonerangerxlt is starting off with a positive reputation.
4.0Beast, you have a 4.0 ohv engine in your 92. The IAC is located on the driver's side of the throttle body. It looks similiar to the one in the above pictures.
FireMarshal, the IAC might be your problem, and that's where I'd start. Try cleaning it and spray the shaft (where it goes into the solenoid housing) with WD-40. If it only stalls when shifting into/out of park or reverse, the trouble could also be in the neutral safety switch.
Old 01-16-2004, 11:22 AM
thelonerangerxlt
when it dies it seems as if it is just not staying at idle, like maybe it isn't getting enought fuel, or being choked out. it has done it while in park idling in the driveway too.
Old 01-16-2004, 11:32 AM
4.0 Beast's Avatar
Turns out its not the IAC, i had my check engine light diagnosed at autozone, and it came up as the right O2 sensor. I went ahead and bought 2 of them, will replace them tomorrow. He said they are responsible for running too rich/lean, and its also related to my low idle/stall problems.....
Old 01-16-2004, 02:57 PM
TartanDon's Avatar
TartanDon TartanDon is offline
TartanDon is starting off with a positive reputation.
Wolfmeister
Nice digital camera you have there, and your not bad on the graphics! Tomorrow morning I am cleaning the MAF and will use your posting to check out the IAC. Thanks for the help.
TartanDon
_________________
97 Explorer 4x4 SOHC
4.0L V6
Old 01-16-2004, 11:12 PM
CarlnLola CarlnLola is offline
CarlnLola is starting off with a positive reputation.
Just another note about the IAC cleaning thing...wolfmeister has a piont about getting solvent in the solenoid (and thus, electircal stuff). After removing the IAC, remove the two phillips screws holding the valve body to the solenoid. CAREFULLY remove the valve body.
Clean valve and shaft by soaking in solvent (I prefer brake cleaner) for about 30 minutes, then drying THOUROUGHLY with low pressure air. CAREFULLY put it back in the solenoid. I don't recommend cleaning anything in the solenoid housing as solvent may get into the coil.
I started experiencing this problem a about a year ago and after testing (per wolfmeister's process except I used a Ford service manual), I ended up cleaning the valve after all electrical tests passed.
That was a year ago and no problems since.
Just my two cents.
Old 01-21-2004, 05:58 PM
Scrapiron66's Avatar
Scrapiron66 Scrapiron66 is offline
Scrapiron66 is starting off with a positive reputation.
Bravo, Bravo
Old 01-27-2004, 07:05 PM
bluedemonss bluedemonss is offline
bluedemonss is starting off with a positive reputation.
hello all. im a newbie here. ill say thanks in advance for all the usefull info provided here to work on my truck
97 explorer 4.0 sohv motor.
got a question though. just got a new idle air control valve about 5 mins ago. went to the company that made its website to match up part # out of curiousity cause it looked different than my stock one. on mine there is a black **** that turns. not sure what it is,looks like an adjustment ****. but the new one just has a steel cap on top.
according to their site (they show pictures of the parts)http://www.smpcorp.com/download/web...talog_frame.asp
the one shown for the 6 cyl has **** and the 8 cyl has a metal cap. the box says the 6 cyl part # but the IACV looks like 8 cyl model.
so my question is before i put it on, whats the **** for and whats the difference between the 6 and 8 models.? will it mess anything up? the guy at the auto parts store said it would work. figured id check with the experts here first.
thanks in advance
Old 01-27-2004, 07:46 PM
powermn12 powermn12 is offline
powermn12 is starting off with a positive reputation.
Mine has a black cap too. I'm pretty sure its just an air vent.
Old 01-27-2004, 08:26 PM
you are probably right about the air vent thing. i have haynes manual and searched many forums online about it and came up with nada.
i went out in the snow storm here to match it up.(im hard headed like that).
matched up fine, holes lined up. only thing is the connection where you plug wires in is aimed straight up, which might not let the plastic cover to be put back on the engine. is there a way to twist the solenoid part to the right like the factory one is?
also is the part for v8 and v6 different?
thanks.
  #28
Old 01-28-2004, 04:37 PM
99expxltgold 99expxltgold is offline
99expxltgold is starting off with a positive reputation.
Sorry if the question may seem dumb, but wann make sure:
So a reading of O.L means the IAC is probably broken?
thanks
  #29
Old 01-30-2004, 05:10 PM
To answer my own question after waisting 70 bucks. O.L is ok.
  #30
Old 02-01-2004, 11:49 AM
flathead239's Avatar
flathead239 flathead239 is offline
flathead239 is gaining momentum as a positive member of FTE.flathead239 is gaining momentum as a positive member of FTE.
Have an '02 with same motor- believe the IAC is different...can anyone verify?
AAA Tests Top Tier & LAC Gasoline Deposits pawpaw Oil & Lubrication 2 09-05-2016 11:02 AM
AAA Tests Top Tier & LAC Gasoline Engine Deposits pawpaw Ranger & B-Series 5 09-02-2016 02:55 PM
Bronco II Tire Cover For Sale chuter Ford Truck Parts for Sale 3 06-01-2016 03:44 PM
Any thoughts on the value of a 79 f350 supercab 4x4? '94Nichols 1973 - 1979 F-100 & Larger F-Series Trucks 12 03-13-2016 10:00 AM
Tech Info pawpaw Oil & Lubrication 0 06-09-2013 07:30 PM
Tags
2001, air, bypass, control, electrical, ford, iac, idle, ranger, resistance, sport, trac, tube, vacuum, valve, voltages
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
