Hydraulic Clutch for 73 to 79 model? - Ford Truck Enthusiasts Forums
Old 10-28-2003, 07:17 AM
Pitdogbrooks Pitdogbrooks is offline
Pitdogbrooks is starting off with a positive reputation.
Any body know of a kit to install a hydraulic clutch on a 73 to 79 1/2 ton truck . Any help would be appreciated.
Old 10-28-2003, 07:31 AM
tellico racing's Avatar
tellico racing tellico racing is offline
tellico racing is gaining momentum as a positive member of FTE.
I dont know of any kits, but the later trucks had hydraulic clutches in them.
Get the bellhousing,slave cylinder,master cylinder, and linkages from a salvage yard, fab up all your own mounts ect, and you should be good to go.
Why do you want hydraulic? sounds like a hassle to me.
Old 10-28-2003, 09:59 AM
BigBully BigBully is offline
BigBully is starting off with a positive reputation.
I done Hydraulic from a 97 F250 Because I used a 97 ZF5 speed and it takes Hydraulic. It was pretty easy to do.
Hydraulic Clutch Adjustment? 1saxman 2004 - 2008 F150 3 12-06-2016 09:38 AM
Dorman 628-200 wtroger 1987 - 1996 F150 & Larger F-Series Trucks 2 07-01-2016 07:09 PM
1991 F150 clutch slave removal dconrads 1987 - 1996 F150 & Larger F-Series Trucks 3 01-08-2015 10:32 PM
ZF S5-42 Tranny Hydraulic to Manual CLutch Mod Questions martinez53 Clutch, Transmission, Differential, Axle & Transfer Case 5 01-16-2011 05:56 PM
f150 clutch engages high? what does this mean? geotracker91 1987 - 1996 F150 & Larger F-Series Trucks 1 04-26-2008 05:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
