Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Exhaust Systems
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-27-2003, 02:48 PM
Loser
Ford79 is gaining momentum as a positive member of FTE.Ford79 is gaining momentum as a positive member of FTE.
Check it out
regarding emissions equipment.. http://www.ford-trucks.com/forums/sh...hreadid=162232
__________________
Mike
2001 F350 CC LB 7.3 Powerstroke
DP Tuner, 5" Straight Pipe, 6" SS tip, 3 Guages, SS HPX, AIH Delete, ATS Housing, 6637, OBA, ITP in-tank and pre pump, 4" lift, 20x10 Mazzi Hulk's, 305/55/20 Toyo A/T's
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-11-2003, 08:23 PM
WheelMA1's Avatar
WheelMA1 is a splendid one to beholdWheelMA1 is a splendid one to beholdWheelMA1 is a splendid one to beholdWheelMA1 is a splendid one to beholdWheelMA1 is a splendid one to beholdWheelMA1 is a splendid one to behold
Also, for anyone who is interested, please visit this site to understand how a catalytic convertor works!
http://auto.howstuffworks.com/catalytic-converter.htm
I hope that helps clear up some questions.
Rich
__________________
Rich
GC/04-08 F150/Big Bronco Moderator
FTE Guidelines
Support FTE!
Support American Manufacturing!
"Made in the USA"
  #3 (permalink)
Old 01-04-2004, 11:11 AM
fordman428's Avatar
fordman428 is starting off with a positive reputation.
that was a very good post about emissions, im glad you mentioned it to us.
  #4 (permalink)
Old 05-22-2004, 05:30 PM
75Player's Avatar
75Player is starting off with a positive reputation.
Rich
I love that site!!! I used it a few months back. As dumb as this will make me sound, after driving a stick for almost 10 years I finally got curious about how a clutch works. The howstuffworks site showed exactly what I was after, and simple enough for a dummy like me to understand.
  #5 (permalink)
Old 02-12-2005, 11:45 PM
David95Ford is starting off with a positive reputation.
Thanks! Very helpful!
  #6 (permalink)
Old 05-10-2005, 05:04 PM
nieking is starting off with a positive reputation.
I have a question that I hope someone can help clarify.
I own a 2002 Ford Escape with the 3.0L. The exhaust system (behind the cat) runs through a HUGE resonator, then through an approximate 4’ length of pipe and finally to a tiny muffler 12” from the tip of the exhaust. The system is so quiet that I can hardly tell that it is running. Not that that is bad, it is the purpose of the muffler of course. Well, for fun the other day I unbolted the muffler flange and completely removed the muffler from the exhaust system leaving only the HUGE resonator. When I started the engine it sounded exactly the same. It was absolutely quiet at idle and no different when revved up. When I shined a flash light in the resonator it looked full of baffles. When I looked through the muffler I could see completely through. It reminded me of a cheap glass-pack muffler.
My goal is to free up the exhaust a bit and NOT touch the cat or affect the emissions in any way.
My local muffler shop said that they could cut out the resonator and weld in a Flowmaster 40 series, then run a straight pipe the rest of the way out.
Q: Will this alter my emissions? I need to be able to pass in California.
Thanks for any advice.
Nieking
2002 Escape XLT, V6, 2WD
  #7 (permalink)
Old 07-17-2005, 08:48 AM
hdandb is starting off with a positive reputation.
smog pump
I am looking to gain about 1/2 hp, can anyone tell me how to remove my smog pump?
  #8 (permalink)
Old 10-26-2005, 11:27 PM
Bdox's Avatar
Iconoclast
Bdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud ofBdox has much to be proud of
Removing the smog pump is as easy as unbolting it. But don't bother. It will make your vehicle illegal and you can pick up power with free flow exhaust and improved intake. Legal and a much larger horsepower gain. Removing the smog pump will devalue your vehicle and my cause problems. Any power you gain by removing it would not be noticed.
  #9 (permalink)
Old 03-26-2006, 08:31 PM
crazypaw's Avatar
crazypaw is starting off with a positive reputation.
Thumbs up
Hi nieking,
Find out if it's legit to run w/o a muffler on your system!
Did you road test / run your vehicle w/o the muffler to check performance?
Incorporate a muffler w/ bigger openings to also keep it legit (legal)!
California is big on emissions controlling...cut your breathable air w/ a knife, you can!
__________________
90' Ranger XLT 2.3 EFI / EEC IV M5OD 4X2 "RustyBeast" is she!
84' Jeep CJ 4X4 4.2L Warner SR-4 trany / Dana 300 diff / Dana30 front axle / AMC rear axle / DURASPARK II w/ Fiberglass Body & a lots of fabrication!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
