Why will my Window Washer not work?
Well replaced, Washer pump inside the resevoir, still not getting fluid to my winshield, also blew into my lines with little effort and got fluid to come out onto my windshield, also pushed in Multfunction switch on column while having washer pump still connected and did not get any power to the pump. Heard clicking noise coming from Window Module behind glove box and assume if its clicking when I push in my switch that it must be working properly, am I correct or does my Window Module need replaced? Any help would be appreaciated. Thanx.
Hey there,
I had the EXACT same problem last year. I could hear the relay clicking, and even after replacing the pump, still no fluid. Ended up replacing the plug that goes into the washer pump. The wires were routed with too sharp of a bend, and they broke. Try that. 10 bucks at the dealership (steep) for the connector. Soldered in, and all is well.
Hope this helps.
Tim in Detroit
95 f150 xlt, 5.8litre, sc,sb, e40d
Hope this helps.
Tim in Detroit
