Ranger 2.5 high torque,low RPM hesitation/studder
I would like to run a problem with my 98 Ranger,2.5,5-spd by everyone and see what you think. During low RPM high torque situations(like starting on a hill) it hesitates and studders badly. Only high revs and slipping the clutch will get it going. Yet "normal" easy acceleration and highway driving is fine. Only sometimes hard acceleration will cause a miss,but accelerating at highway speeds is good. Seems to be worse after warmup. Idles slightly rough.
The first origonal problem was very hard starting and pinging. I replaced the plugs,wires,fuel and air filters(30kmi on them) which made it run better but not perfect. I replaced the MAF and upstream O2 sensor and the low rpm power and rough idle problem is all that Im left with.
This motor has 186kmi on it and since 2 months ago has ran/idled perfectly. Oil changed every 3kmi and I plan on running it till 300kmi.
Thanks for your time,
bnj
bnj
anfo
1997-2006 Expedition & Navigator
01-04-2008 02:13 PM
