Hello,
The door adjustment is accomplished through loosening the door adjustment screws in the front doorjam. The process involves backing off the screws and moving the door around. It is a simple process and also a simple one to screw up and have a worse problem. If you take your time, dont take the screws out and dont back them off too far, you can get a pretty good fit. One thing to consider is that your hinge and bushing may be worn out. If the door sags any while open and doesn't fit flush, it may be time for new hinges. The Haynes manual has a good instruction for both issues.
Eric
__________________
99 EB Expy-Stocker
93 XLT Explorer
