road noise
I also own a 2003 xlt and reciently had my tires rotated (same as yours) and since then am hearing (hard to describe) but something similar to a whining or groaning noise that varies in pitch based on the r's. To me, it sounds like a wheel bearing??
I am considering having my dealer look at it but feel a bit stupid since there may not be anything wrong with the truck.
Anyone having a similar experience???
I belong to another forum/site and several people have had problems with factory tires. I drive highway miles only so I switched to some Yokohama Touring tires a few thousand miles back. Huge difference in road noise and ride. Even if you want to stay with an A/T tire, going to a quality tire can make a difference.
I have the same problem with my 2003 Escape. It is almost certainly the lousy tires that come with it. I had the dealer rotate and rebalance the original tires and there was a world of difference for a while, then it started up again. It's the tires. On my new F150 I got the dealer to switch out the Continentals for some Michelins on another truck. Don't take your next Ford with these crummy tires. I will never have another set of Continental tires except maybe for my lawn tractor.
Since 2001, one of the most identifying characteristics of the Escape is the inordinate level of road noise compared to other SUVs/Trucks despite having the windows rolled up and cruising on smooth asphalt. The body construction does not attenuate sound well. My cheap fix: turn on the radio.
My 2005 has the factory tires, I had to turn up the music to forget I am driving with cheap tires. At 65 mph on brand new snooth freeway, it is pretty quiet. On other road, it is too annoying.
Anyone else have suggestion on quiet tires ?
Another noise related problem I have is when wind blow from the left side.
Is the noise actually wind noise or a rattle? I had a problem where the plastic cover on the bottom of the outside mirror would rattle when the wind was blowing against the driver's side.
