Need Some Advice
Need Some Advice
I have a ticking noise coming from the water pump area. I have taking the belt off and still get the noise. removed the timing chain cover and checked timing chain, it was in spec. When I was look I noticed that I could move the gear for the balance shaft with two fingers my shop manual does not have a step to check the balance shaft. This is on ford F150 198 with v6 4.2L
Thank you for any help
hmm, I don't think this will help, but try this site:
www.leakingfords.com
Also, I would check for leaks.
If your losing power than it's not the relief valve. Everyone's 4.2 has a slight tick to it. I think that what your experiencing is something more significant.
Try that leakingfords.com site. I've read it myself quite some time ago. This could be your problem. especially if you have a 97 or 98 motor.
Tom
Tom
Space Truckin'
09-11-2022 07:01 PM
dgrant09
04-20-2008 04:06 PM
