junkyard d60 rear disc setup
Ok my buddy has me thinking about rear discs now. He has a Dana 70 in the rear of his 4x4 and he put them on it himself with junkyard parts. He used backing plates and calipers from a chev 4x4 1/2 ton and regular ford eight bolt rotors. I was looking at it last night and it looks really clean. He didn't put on any emergency brakes but he said I would just have to get calipers for a caddy or something. The reason I'm thinking about it is because I have to change out the housing and do the brakes on my dana 60 (mine's bent) and I figured discs would be better for towing and maybe save me some weight as well. Any thoughts?
Guys this is the route I was thinking about taking with my 70 crewcab after I get my D44 disk up front done then a rear disk from these guys. http://www.pirate4x4.com/productreviews/disk_brakes/
I am Keeping my rear drum disc's burn up alot fasted then drum and they get more bite it what the 18 wheeler use and mine stock just fine so i dont think i want to put disc's on the rear of a F-250 or any biger maybe a 1/2 ton tho.....but if it work out let me know always open to new idea's
Rear disc's
All the new fords pu come factory w/ rear disc brakes even the f450 w/ dana 70 .
If you have huge rubber and want better stopping, the best easist way is to use bigger diameter rotors. GM's P chassie (bread van) use's the jb8 rpo and a dana 70 rear axle. the only draw back is they need a drive shaft pbrake.
I'm not sure which of the new ford rdisc will lend it self to reto'ing old stuff, hav'nt play'd w/ them enough yet. Ford new stuff has a pbrake similar to the corvette, 2 small shoes using the center of the rotor for a drum cable activated.
Check them out and tell me what you think
Wes
Wes
Here's another, all Ford, option.
NORTH COUNTRY SPECIALTIES ®
There is a reason almost everyone has gone to 4 wheel discs.
on
There is an easier all-Ford option. As Econolines used Dana 60's to the end of their life, then grab a set of rear disc brakes from 99+ (Jeff knows when they started rear disc brakes exactly as I took a quick look at NAPA for parts) E-250/350's at the JY. No having to fiddle with stuff to make it work.
on
1999 was phase-in of the disc brakes so they had both for 99, as per Jeff. After that were used until 2013. I believe that they have integral e-brakes like the SD's, but I haven't looked under one. I could run down to a friends and check his. They do use 8 x 6.5" wheels which are not what SD's use.
