EFI 460 in 78 F250
EFI 460 in 78 F250
as for installing the engine itself is simple, the wiring harness is simple, the fuel system can be tricky, I have personally done this swap into my '79 Bronco
http://voyager.angelheadedhipsters.com/bronco.htm
My trips from here to Anchorage are getting to be expensive.
The fuel cost for the 460 is in the neighborhood of $800 where the same trip with a 300 six would be just over $300. And the Six will pull my 7000# boat if it's necessary although I usually borrow my son's 73 F-250/360/C-6 though. So much power, and so reliable.
That 460 will get mpg into the upper 11's if I keep from stabbing it. Cruise control will add another mile to the gallon too. 35#'s of air in the tires will help but it's a little noisey that way.
However going through British Columbia, Yukon Territory and the Alaska Hiway it's not possible to get over 8-9Mpg. The roads are such that you are on/off the gas way too often. F.I. would definatly help on that trip. I never get tired of making that trip.
yeah, the FI will help, becasue your fuel is metered better into the engine, now when I finish doing a few mods to my wiring harness/engine, I hope to be getting a little bit better mileage, as I will be going to SEFI from bank fire, and also putting in Mass Air instead of Speed Density, which should help a MPG or 2
mike83f250
02-19-2010 10:53 AM
mando jake
11-17-2008 02:02 AM
Mudman
09-18-2006 09:41 AM
WWB F250
07-05-2006 08:00 AM
Rich
07-11-2000 11:32 PM
