No More FL-400S filters for me!
on
1 Post
For some time I have suspected the bigger FL-1A would fit my wife's 3.0 Aerostar, which is specified to get the tiny FL-400S (S apparently stands for small). Last night I pulled the 400S and using calipers measured the FL-1A gasket and found it will fit the gasket mating surface of the 3.0 V6. The only problem was the starter hot cable stuck out near the filter and it would fit but be too close for comfort. No problem, I disconnected the negative cable from the battery, loosened the hot lead, swung the hot cable around about 90 degrees, and retightened the lead. Now the lead is not sticking out by the filter. I screwed a FL-1A on for fitment and it is perfect. No clearance problems, at least 5/8 inches all the way around, easy to tighten by hand, and about 1 inch clearance to exhaust pipe. But since I had another 400S and was only part way through an oil change, I put the new 400S on and will start the FL-1As next oil change. The FL1A is about 2/3 greater capacity. The pleats in the FL-400S are 7/16" deep, whereas the FL-1A pleats are 3/4" deep. Should give much freer flow, I would think. Price is about the same.
Re: No More FL-400S filters for me!
I use the FL400S on my 150 as well and I've never really thought of it as that small. You should see some of the filters that I have had on my Hondas and Nissans. Now those are SMALL.
Paul,
Like Brons2, I'd wonder about the bypass valve. But, in general, I'd wonder; if the FL-1A fits and works, why would Ford use the FL-400?
Makes me wonder.... there might be something we're not thinking of here.
I'm guilty of "if it ain't broke, don't fix it" in this case.
I'd stick w/ the FL-400.
Thanks.
Thanks.
on
1 Post
I compared the return springs on several filters for my pickup truck which takes FL-1A with a FL-400S. I could not detect a difference between the spring tension on the FL-1A and the FL-400S, nor the Purolator, but the Wix filter seemed a tad stiffer and the spring wire even looked a bit thicker. Frankly I don't see a problem with running a FL-1A on the 3.0 V6, though I will research a bit more. Have a couple thousand miles before the next change. Looking at the filter selection charts in the Auto Parts store I see that the older Aerostars that had 2.8 and 2.9 (2.9?--never heard of that one in an Aerostar), both take FL-1A. I think it is a physical space issue, perhaps as evidenced by my having to move the starter hot cable to make space for the wider FL-1A. But hey, either filter costs the same, right? So why not run the bigger one?
Bob, I understand your reasoning, but consider this. There is a significant amount of oil film strength coating the moving parts of an engine when you drain the oil during the oil changing routine. Then, even though the new oil filter is dry, you have already poured 4 1/2 to 5 quarts of fresh oil through the top of the engine, hence providing even more start up lubrication. this is why, I beleive no manufacturer recomends in their owners manuel that the oil filter MUST be filled prior to starting. The only scenerio I would feel you have concern for start up wear (as you stated) would be if you changed the oil and filter, then did not start up the engine for a month in cold, winter temperatures. An empty new filter, then, might cause some wear issues. Just my opinion... ED
on
1 Post
You ought to see the 7-inch-long F700 filter I am putting on the pickup! Talk about a long time filling. But not to worry, I prefill all my filters.
OK. I walked into Meyers auto parts dept. There was a Purolator Filter Catalog from which I obtained the following:
92 Aerostar 3.0 oil filter: L20195
95 F150 4.9 L oil filter: L30001
Specifications in back of catalog:
L20195
Connection Size: 3/4-16, UNF-2B
Flow Rate (GPM): 3
Relief Valve Pressure (PSI): 8 - 11
L30001
Flow Rate (GPM): 4
So they are fully interchangable and you get better flow with the larger filter. Same price, I am running the bigger filter. I also think the smaller filter gasket does not line up to the 3.0s mount because there is a crud ring around the outside of the mating surface. I will measure next time the filter is off and am guessing the smaller filters gasket hanges over the inside edge--perhaps a poor application for some engineer who was worried somebody would change the starter and ground with the filter.
BTW, this Purolator spec table is very valuable as there are a number of filters that do not have the bypass valve, presumably the cars they fit have it built into the oil filter mount.
L20195
Flow Rate (GPM): 3
L30001
Flow Rate (GPM): 4
The "S" in the FL-400S means the gaslet has a silicone lubricant on it.
I've often wondered about the FL-1A, since it has been standard Ford filter for how many years. I use the FL-400S on my '91 Ranger w/3.0 along with Mobil 1 synthetic oil. I love that stuff! My truck has 168,000+ miles on it and NO sludge build-up of any kind. I change it every 10,000 miles or so, and the filter every 2-3000 miles, and sometimes I woder if I even have to do that. The engine continues to run better than the Eveready bunny
My question, though; I always use Motorcraft oil filters. Is this necessary, or are other brands as well suited for Fords?
Bob
Bob
on
1 Post
on
1 Post
[i]
Bob [/B]
Bob [/B]
-Matt
Paul, I worked at the lube rack part time for several years and the FL1A was not a suitable sub for the FL400S or vice versa. Check your threads on your filters. I am almost positive they are different. I remember checking this out once. They are very close but a different thread. Maybe I'm wrong. I hope so.
