95-96 Cold start hesitation/stumble TSB
'95 4.0 AWD. I've been having problems on a cold start that there will be a hesitation/stumble on first take off. I've cleaned the IAC but this tsb seems to say I need to replace it. I'm gonna do that tomorrow!!
Found a TSB:
Engine - Hard Starting/Long Crank/Stalling
Article No.
97-9-5
04/28/97
LONG CRANK - STICKING IDLE AIR CONTROL (IAC) VALVE - VEHICLES BUILT FROM 11/1/94 THROUGH 3/30/96
STALL - AFTER STARTING WHEN ENGINE ALLOWED TO SOAK FROM 1-4 HOURS - STICKING IDLE AIR CONTROL (IAC) VALVE - VEHICLES BUILT FROM 1/11/94 THROUGH 3/30/96
FORD:
1995-96 CONTOUR, CROWN VICTORIA, ESCORT, TAURUS, THUNDERBIRD
1996 MUSTANG
LINCOLN-MERCURY:
1995-96 CONTINENTAL, COUGAR, GRAND MARQUIS, MARK VIII, MYSTIQUE, SABLE, TOWN CAR, TRACER
LIGHT TRUCK:
1995-96 AEROSTAR, BRONCO, ECONOLINE, F-150-350 SERIES, RANGER, WINDSTAR
1996 EXPLORER
This TSB article is being republished in its entirety to include the 1995 4.6L Thunderbird/Cougar.
ISSUE:
After a 1-4 hour engine soak time, long crank times and/or long crank to start followed by a stall may occur on some vehicles. No further stalling or rough idle will occur after the engine is running. The long crank and/or stall may be due to the Idle Air Control (IAC) Valve sticking.
ACTION:
Replace the AC Valve with a revised AC Valve if no Diagnostic Trouble Codes (DTCs) are present. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
1. Perform normal diagnostics and correct any DTCs as required by referring to the appropriate year Powertrain Control/Emissions Diagnosis (PC/ED) Service Manual.
2. If no codes are present, replace the IAC Valve by referring to the appropriate model/year Service Manual, Section 03-14. Refer to the following Idle Air Control Valve Application Chart for proper IAC usage.
Found a TSB:
Article No.
97-9-5
04/28/97
FORD:
1996 MUSTANG
LINCOLN-MERCURY:
LIGHT TRUCK:
1996 EXPLORER
ISSUE:
ACTION:
SERVICE PROCEDURE
Update: after replacing my '95 IAC with a '93 IAC the problem has definitely reduced but it's not totally gone away yet. I did disconnect the battery for 20 mins. I'd like to try a brand new one but they're about $90 here in Canada vs. the used one at $35. It definitely has increased the idle speed in the cold weather - the other one was certainly malfunctioning.
Advance read the codes for me and found 3. They were "Engine Coolant Temp--Circuit Low Input", "Camshaft Position Sensor A - Bank 1--Circuit Malfunction" and "EVAP Emission Control System--Cntrl Valve Malf".
I bought the Camshaft Position Sensor to replace it. Found the magnant broken of the old one and the cam bent. The new one would not fit. Purchased the cam syncronizer. Have not itstalled it yet but expect that to solve the Cam Position Sensor trouble. Don't know about the others yet.
you may have a bent shaft on the cam sensor position unit or a broken worn gear causing shaft wobble.
the ECT is the likely cause of the hard cold starts and rough cold idle. may be sensor or its wiring/connectors
common Ford failure
2 wire sensor on side of thermostat housing outflow tube to radiator.
Ford Fuel Injection Engine Coolant Temperature Sensor (ECT)
includes testing instructions for sensor
common Ford failure
ECT is likely pooched, sounds like cold start enrichment is not happening.
Also you need a junkyard Camshaft Synchroniser with CMP sensor on it ( about $30-40 where I am). The unit needs to be timed; note where the old one is before you remove it & put the replacment in the SAME position , don't allow the engine to rotate .
ATB Aeroman.
97ExpGuy
1997-2006 Expedition & Navigator
77
03-13-2022 08:13 PM
AZcowboypilot
29
07-06-2019 12:33 AM
FordMac1
12-14-2016 07:17 AM
DBGrif91
07-26-2016 07:26 PM
Tim Hodgson
12-23-2015 07:08 PM
