95-96 Cold start hesitation/stumble TSB - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 10-24-2003, 01:57 AM
aletheuo aletheuo is offline
aletheuo is starting off with a positive reputation.
'95 4.0 AWD. I've been having problems on a cold start that there will be a hesitation/stumble on first take off. I've cleaned the IAC but this tsb seems to say I need to replace it. I'm gonna do that tomorrow!!
Found a TSB:
Engine - Hard Starting/Long Crank/Stalling
Article No.
97-9-5
04/28/97
LONG CRANK - STICKING IDLE AIR CONTROL (IAC) VALVE - VEHICLES BUILT FROM 11/1/94 THROUGH 3/30/96
STALL - AFTER STARTING WHEN ENGINE ALLOWED TO SOAK FROM 1-4 HOURS - STICKING IDLE AIR CONTROL (IAC) VALVE - VEHICLES BUILT FROM 1/11/94 THROUGH 3/30/96
FORD:
1995-96 CONTOUR, CROWN VICTORIA, ESCORT, TAURUS, THUNDERBIRD
1996 MUSTANG
LINCOLN-MERCURY:
1995-96 CONTINENTAL, COUGAR, GRAND MARQUIS, MARK VIII, MYSTIQUE, SABLE, TOWN CAR, TRACER
LIGHT TRUCK:
1995-96 AEROSTAR, BRONCO, ECONOLINE, F-150-350 SERIES, RANGER, WINDSTAR
1996 EXPLORER
This TSB article is being republished in its entirety to include the 1995 4.6L Thunderbird/Cougar.
ISSUE:
After a 1-4 hour engine soak time, long crank times and/or long crank to start followed by a stall may occur on some vehicles. No further stalling or rough idle will occur after the engine is running. The long crank and/or stall may be due to the Idle Air Control (IAC) Valve sticking.
ACTION:
Replace the AC Valve with a revised AC Valve if no Diagnostic Trouble Codes (DTCs) are present. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
1. Perform normal diagnostics and correct any DTCs as required by referring to the appropriate year Powertrain Control/Emissions Diagnosis (PC/ED) Service Manual.
2. If no codes are present, replace the IAC Valve by referring to the appropriate model/year Service Manual, Section 03-14. Refer to the following Idle Air Control Valve Application Chart for proper IAC usage.
Old 10-27-2003, 06:09 PM
Update: after replacing my '95 IAC with a '93 IAC the problem has definitely reduced but it's not totally gone away yet. I did disconnect the battery for 20 mins. I'd like to try a brand new one but they're about $90 here in Canada vs. the used one at $35. It definitely has increased the idle speed in the cold weather - the other one was certainly malfunctioning.
Old 07-10-2008, 02:50 PM
rjb0722 rjb0722 is offline
rjb0722 is starting off with a positive reputation.
1996 Ranger 3.0. Hard to no start in the morning. After warm or runs a while, starts and run fine. Was told it could be the cam position sensor? Any suggestions?
Old 07-10-2008, 04:11 PM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
rbj0722
welcome to FTE and the Aero forum
your engine control computer is OBDII EEC-V
lots of guesses for cold start problems
have the codes read for free at auto parts store, call ahead
post codes here.
or buy/borrow code reader/scanner
same engine as used in later Aeros
Old 07-13-2008, 04:11 PM
Advance read the codes for me and found 3. They were "Engine Coolant Temp--Circuit Low Input", "Camshaft Position Sensor A - Bank 1--Circuit Malfunction" and "EVAP Emission Control System--Cntrl Valve Malf".
I bought the Camshaft Position Sensor to replace it. Found the magnant broken of the old one and the cam bent. The new one would not fit. Purchased the cam syncronizer. Have not itstalled it yet but expect that to solve the Cam Position Sensor trouble. Don't know about the others yet.
Old 07-13-2008, 05:24 PM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
There is one big engine wiring connector. Try to disconnect it, inspect for corrozion, clean if neccesary.
Old 07-13-2008, 08:06 PM
96_4wdr's Avatar
you may have a bent shaft on the cam sensor position unit or a broken worn gear causing shaft wobble.
the ECT is the likely cause of the hard cold starts and rough cold idle. may be sensor or its wiring/connectors
common Ford failure
2 wire sensor on side of thermostat housing outflow tube to radiator.
Ford Fuel Injection Engine Coolant Temperature Sensor (ECT)
includes testing instructions for sensor
Old 07-13-2008, 11:42 PM
Aeroman59's Avatar
Aeroman59 Aeroman59 is offline
Aeroman59 is starting off with a positive reputation.
The evap Purge control valve or solenoid gets sticky due to carbon dust build up. Take off the purge solenoid & blow out the lines & spray carb cleaner into the solenoid ports, while shaking out the gunk. You can also energise the solenoid with a 12 v source & you will hear the valve open & close while touching the terminals. If nothing happens reverse the wires. Blow through the ports with an air gun while this is going on (need an assistant). At the engine wire plug to the solenoid: this connection to the solenoid should be come live 12v at about 1500 RPM's intermittently which opens the purge valve, if not you have an electrical or ECU problem. Check wires to ECU. It is also possible the purge flow sensor is faulty if yours has one. You can try the same air blow carb cleaner trick on it, but might need a new one.
ECT is likely pooched, sounds like cold start enrichment is not happening.
Also you need a junkyard Camshaft Synchroniser with CMP sensor on it ( about $30-40 where I am). The unit needs to be timed; note where the old one is before you remove it & put the replacment in the SAME position , don't allow the engine to rotate .
ATB Aeroman.
TSB 95-15-11 NO START, HESITATION-STUMBLE- INTERMITTENT STALL 4.9L, 5.0L, 5.8L AND 7.5L ENGINES Tim Hodgson 1978 - 1996 Big Bronco 1 12-30-2015 09:34 AM
Lack of Power Spark Knock/Detonation Buck/Jerk Hesitation/Surge on Acceleration 96_4wdr Aerostar 0 03-03-2015 01:19 AM
Why our trucks SUCK- colemanw 1987 - 1996 F150 & Larger F-Series Trucks 27 09-16-2012 03:31 PM
Why is my engine idling too fast? JohnPeter 1968-2013 Full Size Vans 0 04-02-2011 06:02 PM
Check this out! Good diagnostic info... emtabmm 6.0L Power Stroke Diesel 0 11-21-2003 09:44 AM
Tags
117, 1995, 1996, 40, 95, aerostar, code, cold, engine, f150, ford, hard, hesitation, mercury, mystique, start, thunderbird, trouble, tsb, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
