valve seal replacement
I have a '91 F250 with a 460. It doesn't leak oil but smokes some under hard acceleration and consumes about a quart of oil per week. I'm assuming that the valve seals need to be replaced and I'd like to hear from whoever has done a valve seal replacement concerning how difficult it is and what to look out for.
Thanks in advance for your replies.
Very easy to do, I did them last summer. The only real important thing to look out for,, be aware of,, is dropping the valve stem into the head. Make sure you have it securely held up during the seal replacement. I used two sets of needlenose vise-grips with sponge coverings for the jaws. Hold it near the bottom, slip the seal on, then hold it at the top with the other, then release the bottom one. Just Make Sure you don't let it go. Other than that, piece of cake.
you need an air compressor and a fitting for the spark plug hole.
Then go to AUto-Zone and rent thier tool for that purpose. It's a piece of cake.
Before you go to all that trouble, make sure you dont have a lot of blow by! You could have trouble with the RIngs, or an intake manifold gasket leak too.
Do a wet and dry compression test to make sure.
OR,
You can also feed some rope in through the sparkplug hole & bring the piston up to it holding thew valve in place.
The fastest way to do all of them is find the mention of 3 positions of the crank to be placed.Use the air pressure making sure the crank doesn't spin when applying air, turn the crank to its proper 3 positions and do 5 or 6 at a time.
We used to have a tech ariticle on FTE but it is now gone.
Its pretty hard to check for a leak below the valley, It would probably idle erratic if there was. Is there oil in the lower intake? Your PCV Valve me not be working right. I would also pull the valve covers and check to make sure the drain holes are not plugged. In a lighter note, If you are going thru a quart a week you probably never have to change the oil just the filter once in a while. I guess I dont know anything else.
cbakker
09-14-2012 09:59 AM
ReGGaTarT
02-07-2007 11:46 PM
