95 mass air conversion
i just got off the phone with the ford perfomance techline i was told it should work, the wiring harness will fit fine. the only difference is the lightning throttle body is a single bore not dual like the regular f150s. i was told they cant guarantee it fits because they havent done it in house but several people have used the kit on regular f150s and it worked fine
You are going to need a Factory MAF truck intake setup to hook the twin TB's to the MAF meter. It's about $110 @ Ford.
A single 86mm TB is WAAAAY too big. I think a twin 56mm TB is plenty large if you use the Edelbrock EFI truck intake or the stock 351W one.
i am using a 426ci windsor with 351c 4v heads the intake is a 351c tunnel ram that has been converted to be efi the bungs are tig welded into the runners and the top is a custom made plenum setup for the single bore throttle body
That tunnel ram is going to give you an odd powerband of 2500-7500rpms most likely.
If you go to a cam that large, an 80mm TB or slightly larger should work.
I thought you were running just a 357 and wanting that 86mm TB!! hahaha
Originally posted by Jack01
i have a 95 f 150 302(5.0) with a 4r70w and have done a little research into upgrading my truck to a 351w (5.8) and found that i could with no problems.. the 4r70w is an e40d modified.....so you may want to look at that route for your truck...and my truck is maf from the factory....
#28
Scndsin
19
02-06-2019 11:48 AM
95centurion
04-08-2016 03:39 PM
johnboy151a
09-26-2015 08:34 AM
coxthecrazy
86
09-25-2015 11:01 PM
Ryan356
15
02-16-2002 08:41 AM
