Terrible gas mileage! 95 F150 5.0 4X4 - Ford Truck Enthusiasts Forums
Old 11-20-2000, 08:42 PM
bill12468 bill12468 is offline
bill12468 is starting off with a positive reputation.
Motor runs good. Somehow I lost a great deal of power. From a standstill acceleration is poor. Sounds like the K&N filter should be sucking in the hood. Checked vacuum at idle about 17in. Brought to 2000 rpm held same reading. Does this atomatically tell me the cat is good. Fairly fresh motor (50K), 8K on the 4R70W tranny, 250K on the rest of it. Changed plugs, wires, cap & rotor, PCV, fuel filter, O2 sensor, cleaned the K&N filtercharger. Had a few EEC-IV codes, remedied them, did not reappear. Is it possible for sensors like MLP or EVP to appear in range just enough to effect performance, yet not show up in the trouble codes? Come on Guys, the C*%@y guys at work are having a field day with this. They'd never see 250K on one truck.
Old 11-20-2000, 11:22 PM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
Has the timing been checked ?
Old 11-21-2000, 12:13 AM
franklin franklin is offline
franklin is starting off with a positive reputation.
I would check fuel pressure. I take the guts out of
schrader valve on the fuel rail (careful it might squirt
fuel) and slide a hose over the fitting with a hose clamp.
Should be High 30's to low 40lbs. A friend had trouble
with his v6 4.0 and it turned out to be the fuel regulator.
He went to the dealer and they said they have been having
problems with 4.0 fuel regulators. I also have taken my
car to the dealer and they run that cleaner stuff through
the injectors and it does help.
Old 11-21-2000, 10:11 AM
Timing is right on 10 degrees BTDC
Old 11-21-2000, 11:10 AM
walterdanek walterdanek is offline
walterdanek is starting off with a positive reputation.
When you changed your O2 sensor, did you disconnect the battery? I changed mine in my '84, but did not disconnect. Was still getting bad milage, so I called the dealer. He said you have to disconnect the battery for 10 to 20 minutes on any electric gadget. That allows the computer to reset itself. Go figure.
Walter
Old 11-21-2000, 11:53 AM
Walter, will try this. Didn't even dawn on me, should know better. Will let you know the results. Thanks, Bill
Old 11-22-2000, 09:13 AM
fairlaniac's Avatar
fairlaniac fairlaniac is offline
fairlaniac is starting off with a positive reputation.
I feel like somewhat of a dummy. My 1995 F150 4x4 5.0 5spd a/c is the first full blown electronic/computerized vehicle that I've owned. I read in a Haynes manual on changing/correcting ignition timing. I'll be damed if I know what they are taking about. Can someone in plain english tell me how they check timing. What do I disconnect or block. I don't have my manual in front of me so I'm forgetting things. What is Thick Film? Thanks in advance.
Happy Thanksgiving!
Doug
Old 11-22-2000, 11:49 AM
Pastmaster Pastmaster is offline
Pastmaster is starting off with a positive reputation.
Doug, the computer advances the timing, bringing the 10 up to about 17 degrees. So to manually adjust timing, you have to unhook the computer. Over by the cruise control box, on the fendor you'll find a little hookup, that should have a little "connector" inside it. This is the spout connector, with the engine off, unhook it, and then you can check your timing.
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
toydestroyer1(No Email Addresses In Posts!)
Old 11-22-2000, 11:54 AM
Doug,
No such thing as a Ford dummy!
To check the timing, first warm-up the engine. Shut it off and connect the timing light as you normally would (#1 cylinder is front passenger side). Disconnect the SPOUT connector, this is located on the driver's side, between the firewall and engine compartment fuse box. The SPOUT connector will be a single wire with a white plastic removable shorting bar. This bar resembles a long fuse, remove this shorting bar. You now have removed any computer advance. Time the truck to 10 degrees before top dead center. Reinstall SPOUT connector, check with the timing light that the advance signal is working (rev up a little, advance should change).
PS. make sure you are in neutral and wheels are chocked, otherwise it could ruin your holiday. Good luck, Bill
Old 11-22-2000, 12:01 PM
Hey Pastmaster,
This truck is still getting 10mpg. Since replaced coil, no change. Feels like the truck needs a ton a fuel/air to get going. What do you know about Manual Lever Position Sensor on a 4R70W Transmission. Also EVP sensor tested range is 3700-670 ohms, seems too low on the high side and too high on the low side. What do you think? Any info would greatly help.
Thanks, Bill
Old 11-25-2000, 02:07 AM
Superdave Superdave is offline
Superdave is starting off with a positive reputation.
Old 11-26-2000, 07:37 AM
gino93 gino93 is offline
gino93 is starting off with a positive reputation.
my f-150 5.0 4x4 mod was acting funny when i bought it. when i started from a stop i had sluggish power, poor gas milage and hesitation when i romped on the gas pedal. i replaced spark plugs,wires, fuel filter, vacuum leaks (found none), aair filter, checked copm codes all good, cchecked egr good, replaced the tps. you wont believe where i found the problem. it was the map sensor. i replaced it and erased the computor and she has ben running like a gem since. i had the same dilema when i checked my timing. it took me a day to find the spout connector for the timing. all it is is a suitcase jumper. its on the driverside on our truck. good luck
Old 11-26-2000, 09:37 AM
Hey Gino93,
You said when you scanned the EEC-IV, you had no trouble codes. Wounldn't the MAP sensor show up as a code if it was bad? Or maybe it's just not getting the full range. I checked The EGR & EVP. Note EVP range should be greater than 100 to less than 5000 ohms, I have 600 - 3700 ohms. Could this be a functioning sensor but just not functioning in the full range as it should? Could the MAP sensor have a similiar problem? Will test MAP today an see whats up. BILL
Old 03-04-2006, 05:13 PM
dkocian dkocian is offline
dkocian is starting off with a positive reputation.
I have a 1999 Ford F150 with 130,000+ miles on it. Never did anything to it except change the oil. Last few months, it starting getting sluggish, and made a funny noise (like it was chugging) when I started it. Today, the battery died. I replaced the battery, and I could not believe it. It drove like a brand new truck. Better acceleration, smoother, and great gas milage. Never knew the battery could do that, but I think it was because when it went under load, the voltage dropped from 12 to 14 all the way down to about 9. This must have run the computers nuts. If nothing else works for you, try swapping out the battery. Worked for me!
Old 03-04-2006, 05:23 PM
Popa Tim Popa Tim is offline
Popa Tim is starting off with a positive reputation.
As Fairlane suggested, get that fuel pressure tested. Next check for a vacuum leak, my 94 5.o pulls 22 at idle.
Early99 K&N to AIS BadDogKuzz 1999 - 2003 7.3L Power Stroke Diesel 43 09-23-2015 04:32 PM
Cleaning K&N 1L243 1999 - 2003 7.3L Power Stroke Diesel 19 11-03-2013 08:12 PM
6637 mod question tj01536 1999 - 2003 7.3L Power Stroke Diesel 40 07-24-2011 09:00 AM
K&N Filter Fuel Economy Improvement gitane59 Modular V10 (6.8l) 11 07-19-2005 11:59 AM
K&N air filters let too much dirt through??? poopey Oil & Lubrication 16 11-03-2002 08:14 PM
Tags
1995, 2wd, 302, 50, 93, 94, 95, base, connector, f150, gas, litre, mileage, sluggish, terrible, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
