engine vibration on new rebuild
Walt,
It is possible to mess up a harmonic balancer while removing it. if you used a steering wheel puller to remove it, there is almost no chance of damage, if you used a pry bar, you in trouble. If i'm not mistaken, there is a rubber damper in the balancer and it will stick out at one point or another when the outer metal ring has been misaligned. The crank pulley bolts to the inside and will not show signs of vibration unless it, itself is bent.
The next question is; Is the 460 internally or externally balnced? I do not know but, maybe I can find out.
KingFisher
KingFisher
pit_of_pity
17
03-24-2011 04:50 PM
Xwarrior86
01-11-2005 09:12 PM
