89 f150 ignition switch replacement
Old 10-23-2003, 10:50 AM
mep123's Avatar
mep123
mep123 is offline
Angry 89 f150 ignition switch replacement
Has anyone replaced the ignition switch on a 89 f150? This is the one mounted to the steering colunm not the key switch. After replacing switch it appears when I turn the key switch that I can't get enough movement from the actuator arm to turn my truck on. I can remove the mounting screws from the ignition switch and used a screwdriver on it to manually move the switch to the start the truck. I've tried mounting it and adjusting it to where it is at the midpoint of its travel as per the haynes repair manual but to no avail. Please advise.
rhol55
09-21-2016 08:01 AM
rusty_tank
08-19-2016 05:08 PM
89coal-mkr
11-09-2012 07:54 AM
ChurchBuilder
03-22-2007 09:32 AM
89MustangGX
18
03-01-2007 03:46 PM
Quick Reply: 89 f150 ignition switch replacement
