89 f150 ignition switch replacement - Ford Truck Enthusiasts Forums
Old 10-23-2003, 11:50 AM
mep123 mep123 is offline
mep123 is starting off with a positive reputation.
Angry 89 f150 ignition switch replacement
Has anyone replaced the ignition switch on a 89 f150? This is the one mounted to the steering colunm not the key switch. After replacing switch it appears when I turn the key switch that I can't get enough movement from the actuator arm to turn my truck on. I can remove the mounting screws from the ignition switch and used a screwdriver on it to manually move the switch to the start the truck. I've tried mounting it and adjusting it to where it is at the midpoint of its travel as per the haynes repair manual but to no avail. Please advise.
81 F-100 ignition switch sdjustment? rhol55 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 09-21-2016 09:01 AM
Ignition Switch Positions rusty_tank 1987 - 1996 F150 & Larger F-Series Trucks 3 08-19-2016 06:08 PM
89 F250 turn key but no crank 89coal-mkr 1987 - 1996 F150 & Larger F-Series Trucks 1 11-09-2012 08:54 AM
Ignition switch 89 F150 ChurchBuilder 1987 - 1996 F150 & Larger F-Series Trucks 1 03-22-2007 10:32 AM
Ignition Key Problems 89MustangGX 1987 - 1996 F150 & Larger F-Series Trucks 18 03-01-2007 04:46 PM
Tags
150, 1987, 2000, 58, 89, adjust, f150, ford, iginition, ignition, key, location, replace, replacement, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
