sub box for f150 97 club cab
the best way to add bass is with a jl audio stealth box. it has two 8" subs tha fit under the rear seat and it bolts back in the same place. i can space the seat up with washers and get the room you need the a 10". if you are going to build the box yourself than i would go with the 10". i you have to pay someone to do it then i would go with the jl box. it goes for about 500.00 and it and be installed by anyone that can remove and reinstall a bolt.
furrby
furrby
97F250HDFlatbed
11-29-2004 08:23 PM
low92flareside
08-01-2004 09:12 PM
Sporttruck
12-24-2001 08:48 PM
