Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 10-23-2003, 06:57 AM
mgb150 mgb150 is offline
Garage is empty, add now
mgb150 is starting off with a positive reputation.
Question Check engine light, code P-1537 & P-1538 1998 F150 4.2L 6 Cyl
My chk eng. lite yields codes P-1537 & 38 "Intake Manifold Runner Control Stuck Open". If IAC is stuck open would engine still run good at idle? Cleaned MAF, IAC, new air filter. Truck runs perfect at idle with only an occasional buck or misfire upon acceleration at highway speed. Checked for vacuum leak off
PCV to elbow, not an issue. Any ideas appreciated!!!
  #2 (permalink)
Old 10-23-2003, 07:18 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi mgb150 and welcome to FTE
The IMRC and IAC are different. The IAC just controls the idle speed. The IMRC works sorta like a 4 barrel carb. Your intake manifold has 2 ports for each cylinder. It opens the second set of intake ports when under a heavy load or high rpm.
Possible causes: (generic list)
Leaky vacuum reservoir.
Damaged vacuum lines.
Damaged vacuum solenoid.
Damaged vacuum actuator.
IMRC actuator cable/gears seized.
Cables improperly routed (binding) or seized.
Damaged/disconnected IMRC housing return springs.
Lever/shaft return stop obstructed/bent.
Lever/shaft wide open stop obstructed/bent.
IMRC lever/shaft stick/bind or disconnected.
Open IMRC control circuit.
Open VPWR circuit.
Shorted IMRC circuit.
Damaged PCM.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #3 (permalink)
Old 10-27-2003, 07:05 AM
Smile BINGO
Thanks Racerguy, it was a vacuum leak! The lines going to the reservoir. I wish they were all a 15 cent fix.
  #4 (permalink)
Old 10-27-2003, 08:22 AM
Racerguy's Avatar
Thanks for letting us know what fixed it
__________________
Forum Guidelines
this space for rent
Tags
1538, 1998, 42, check, code, e150, engine, f150, ford, imrc, intake, leak, light, manifold, p100, vacuum, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
