Go Back   Ford Truck Enthusiasts Forums > Other Fords > Nite, Nascar and Other Limited Edition Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-23-2003, 06:38 AM
Talyn's Avatar
Bean Farmer
Talyn is gaining momentum as a positive member of FTE.Talyn is gaining momentum as a positive member of FTE.
91 f150 nite =D
Okay, I just baught a 91 nite f150 with the 5.0 (302) and a 5 speed, dual tanks. Its the one without the pin stripeing. 4x2.
The guy i baught it from baught it brand new in 1991.
Anything i should really look into on this truck to get it running real good again?
Its got a new clutch, and new tires.
I gotta do some body work to the bottom body panels, but thats easy stuff. And i have 1 rust spot to fix.
The truck has been sitting for 3 years, so i gotta do a fluid change and stuff. Maybe clean the plugs, I dont have all the cash yet to do a tune up. It is fireing good right now though, so i'm not to concerned yet about that.
Just looking for anything special i should check or make sure is working right.
__________________
Talyn (AKA: William)
Resident Sheep Shearer
Michigan Chapter Leader: Join
1995 F150 (ForSale)
- 302 M5OD 4x4
John Deere 6420
- Power Quad
- Front Assist
- Loader
1978 Harley Davidson (ForSale)
- FLH Electra Glide
- PM for Details
1991 NITE(RIP)
1985 Tempo(RIP)
2002 F150 Flareside
- 5.4L 4x4
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-23-2003, 06:40 AM
Talyn's Avatar
Bean Farmer
oooo! saved by the edit button. I always want to type in NIGHT. not NITE.
Forgot to note, i got it for 1800.
he told me blue book was 2700 for it. And all the prices i see for 91 fords with a v6 are 4 grand. ...
hard to find a full size for under 3,000...
__________________
1995 F150 (ForSale)
- 302 M5OD 4x4
John Deere 6420
- Power Quad
- Front Assist
- Loader
- FLH Electra Glide
- PM for Details
1991 NITE(RIP)
1985 Tempo(RIP)
2002 F150 Flareside
- 5.4L 4x4
  #3 (permalink)
Old 10-23-2003, 07:08 AM
KeelarPluto is starting off with a positive reputation.
I just bought a 90 F150 SuperCab w/ 302 Automatic for $1400, I've been slowly but steadily replacing parts, ie. Plugs, Wires, Rotor, Cap, Upper & Lower radiator hose, Power steering return and pressure line, new tires and dual exhaust and it's finally all set, runs mint.....Just turned 100K, so I think me and you both found good deals, I just wish it was 4X4, of btw. I did a tranny flush as well.....
__________________
-Mike
1990 F150 302 SuperCab 2WD
2002 Mazda Protege 2.0
  #4 (permalink)
Old 10-23-2003, 08:03 AM
Talyn's Avatar
Bean Farmer
Yea, i think i'm going to do a tranny flush.
302 supposto sound tottaly awsome with duals on it. =D
Maybe i go dual flowmasters when i get the $.
Gonna have a mechanic inspect all the hozes for me, thats my main concern is dry rotted hozes. Though most i seen at the glance under the hood look good.
I"m getting the truck later on today. so i'll probably give it an oil change by hand. but muffler man does it for 15, which is cheeper then doing it by hand. so i duno, maybe i take it over there.
__________________
1995 F150 (ForSale)
- 302 M5OD 4x4
John Deere 6420
- Power Quad
- Front Assist
- Loader
- FLH Electra Glide
- PM for Details
1991 NITE(RIP)
1985 Tempo(RIP)
2002 F150 Flareside
- 5.4L 4x4
  #5 (permalink)
Old 10-23-2003, 08:13 AM
Talyn's Avatar
Bean Farmer
Better bust out this question while i remember.
The truck has a small rear main leak.
And i just read about the rubber seal leaking on the mazda transmission.
Not sure about the transmission in the truck either. Is that the one it has?
And, how much will getting this leak fixed cost? Just rough estimate.
I hate leaks, my tempo leaks like a mothertrucker.
__________________
1995 F150 (ForSale)
- 302 M5OD 4x4
John Deere 6420
- Power Quad
- Front Assist
- Loader
- FLH Electra Glide
- PM for Details
1991 NITE(RIP)
1985 Tempo(RIP)
2002 F150 Flareside
- 5.4L 4x4
  #6 (permalink)
Old 10-23-2003, 07:28 PM
BRI-GUY74 is starting off with a positive reputation.
I reciently found a steal of a deal. A 92 f-150 I-6 4x2 92000 for $1100. I did the basic tune-up wires,cap,rotor,oil change,upper and lower hoses flushed the rad. It looks good with a cap and i put new 31 inch tires. Its only problem is it has an issue when starting. You have to hit the gas pedal before it will start. I thought the fuel injected didnt need that. Any one have any ideas why it wont start.
Thanks for any ideas
__________________
92' F-150 2wd
If you can't fix it DUCT TAPE It.
  #7 (permalink)
Old 10-23-2003, 08:28 PM
acerockola77's Avatar
acerockola77 is starting off with a positive reputation.
Post some pics!
__________________
Chris -
94 F150 4.9L
  #8 (permalink)
Old 10-24-2003, 11:08 AM
blakek is starting off with a positive reputation.
also have a 91 f150 daily driver been a good truck
has been a good truck currently has 166000 on it 4.9 six aod pull my boat with it
  #9 (permalink)
Old 10-24-2003, 09:30 PM
Talyn's Avatar
Bean Farmer
Inline sixes are the shazle dazzle.
There one of the best engines you can get. I'm sure you wont ever have a problem with it.
__________________
1995 F150 (ForSale)
- 302 M5OD 4x4
John Deere 6420
- Power Quad
- Front Assist
- Loader
- FLH Electra Glide
- PM for Details
1991 NITE(RIP)
1985 Tempo(RIP)
2002 F150 Flareside
- 5.4L 4x4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
