Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-22-2003, 09:59 PM
slazgolf1 slazgolf1 is offline
Garage is empty, add now
slazgolf1 is starting off with a positive reputation.
Propane Flow Rate?
Anybody know the flow rate of propane with some of these store bought injection systems?
  #2 (permalink)
Old 10-23-2003, 02:34 AM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
I don't know the exact flow rate of the Powershot2000, but when I first got mine, prior to modifying it, the system would exceed the 7 cu ft/min capacity of the service valve on the tank. I've replaced the service valve with a high flow unit that has a capacity of 13 cu ft/min, and haven't exceeded that, yet. The flow rate is somewhere between 7 and 13 cu ft/min.
__________________
When you're walking away from your truck, do you turn around just to look at it? Yeah, so do I. ☺
'13 F-250 Platinum CC SB 4X4 Powerstroke.
  #3 (permalink)
Old 10-23-2003, 08:17 PM
Thanks Quad.
Tags
flow, propane
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
