Horn Relay
Old 10-22-2003, 10:02 AM
GSchretter's Avatar
GSchretter
GSchretter is offline
Question Horn Relay
Where is the horn relay located for a 87 f-150 with a 302 ?
I think my horn replay is going bad.
Sometime I hold the the horn and the horn goes on and off several times no matter how/where I hold the horn down but sometimes it works fine.
Seem to act up when I really need it...
I can hear the relay switching going back a forth.
Thanks.
Old 10-22-2003, 12:40 PM
Ford_Man_302's Avatar
Ford_Man_302
Ford_Man_302 is offline
the one on my 90 is located on the paasenger side in behind the glove box i do believe
Old 10-22-2003, 12:59 PM
DanTana's Avatar
DanTana
DanTana is offline
I also read where it is the relay on the driver side fender next to the firewall. I would like to know because my horn doesn't work either.
Old 10-22-2003, 04:40 PM
mantta's Avatar
mantta
mantta is offline
The ones on the drivers sice fender next to the firewall are the fuel pump and EEC relays.
Old 10-22-2003, 05:21 PM
GSchretter's Avatar
GSchretter
Sounds
Like somewhere under the dash on the driver side since I can hear it relay turning off and on.
Old 10-22-2003, 09:08 PM
DanTana's Avatar
DanTana
DanTana is offline
I'll check under the dash again, I did see a couple connectors under there sort of by the floor pan by the trans hump. It also looked like the computer was there also.
Old 10-22-2003, 10:03 PM
GSchretter's Avatar
GSchretter
I think you got it.
But I wonder which one.
I guess this weekend I replace use a OHMS meter and find out.
Also does anybody know what in the world kind of bolts are used
on a jeep axle.
They look like stars and they are not trox ?
Thanks.
Old 10-23-2003, 10:19 AM
DanTana's Avatar
DanTana
DanTana is offline
I think I'm gonna go to Ford and ask for a horn relay, seems like the only way I will be able to match it up.
rzns60
09-12-2020 12:02 PM
Frank33884
15
03-23-2016 10:29 AM
maldbwmjr
1997-2006 Expedition & Navigator
06-19-2012 01:37 PM
glasers11
10-16-2008 12:07 PM
lee
10-30-2000 12:57 AM
Quick Reply: Horn Relay
